- Joined
- Oct 25, 2019
- Messages
- 11,111
- Likes
- 14,774
Okay, I understand. Thank you for the detailed answer.
Will a portable dac/amp improve the sound reproduction of the MDR-ZX66 (aside from adjusting EQ settings or trying to match the AX-550 sound style)? Will I be able to notice a difference between the external dac/amp and the internal of the laptop/phone?
In all likelihood, no. Those cans are designed to be used exactly as you are using them. They dont need to extra power a dedicated amp can bring. Unless the HP out of your PC/ phone is terrible, I doubt you will get a remarkable transformation with a decent DAC/ amp.
A cheap experiment would be the well measuring meizu hifi dac or perhaps even better the Tempotec Sonata HD Pro which should have ample power for those cans. Both can be had from ali express for $25-40 so its a low risk option.
