To answer your question, I arranged A07 with A04/TPA3255 for several hours in an environment with a room temperature of 20 degrees and observed the temperature change. Both are connected to the same 36V power supply.So you say it gets less hot than the A07? It looks like the internals are pretty much the same as the A07, also the size of the heatsink . What if the connection between the chip and the heatsink is not as good, so that the heat doesn't get transported to the heatsink as well? Or is this not possible because the case would get just as hot?
As a result, both models generate less heat under these conditions, but the temperature of A07, which has a large case, is slightly lower than that of A04/TPA3255.
