MacCali
- Joined
- Dec 21, 2020
- Messages
- 1,141
- Likes
- 549
Yes I believe people were mentioning this, but I did not understand there point. When you’re brainstorming and your mind is cloudy you can’t link those thoughts. Too much going on lolWould a SPDIF or TOSLINK digital output be satisfactory? That would allow you to use any high-SINAD, balanced DAC of your choice. Even my Sony UBP-X700 has an SPDIF output. Not much concerned about jitter from the transport, because even output were jittery, my DAC incorporates ASRC-type circuitry, so data is de-jittered. DACs with balanced outputs are pretty common these days, whereas UHD disk players with same are scarce, and they command top dollar.
Out of curiosity, I popped a CD into my X700, and perhaps anticipating that the user might not care to fire up the TV set just to listen to music, it bypassed built-in apps and went directly to music playback, and all I had to do is press Play. Primary downside with a lower-priced player like mine is lack of any display or navigation controls on the unit itself, so if you misplace the remote or the batteries go dead, I guess you'll have to find something else to do.
I’m sure but was just thinking performance wise, it wouldn’t make a differenceIsn’t the 1100es better? Thought that’s the flagship
@-Matt- I think things start to go missing as you go down. I can double check prior to purchasing. Currently on sale now too the 820
I wasn't making a recommendation for a particular model. I think you had several recomendations from people that actually own players at the start of the thread.Isn’t the 1100es better? Thought that’s the flagship
Isn't the 820 better than the 450? or the 450 has no dolby vision? think the 820 would be better no clue what the future holds.
But I do have my eyes set on that QD-OLED, so looks like I will probably be sticking to samsung.
Basically got to distinguish a lot of crap and decide. The only thing keeping me to that 9000 is the cd function, cause whatever the price maybe you must subtract the value of the cd player from it, that's just the way I look at it. If that cd player is 300 and the unit is 700 for bd function than basically everything else is in that range too roughly
Hmmmm @Laserjock 's last comment just made me realize maybe what you guys are saying......... are you suggesting to just get any bd player with digital out and then feed my dac and basically making the analog outs worthless on the 9000?????
The jitter on the 820 got me questioning the purchase.450 lacks Dolby vision. Probably build differences.
The UB9000 would make a great CD player. Quiet transport and good analog outputs.
The DACS on the 9000 are really good if you are using it in analog compared to receivers, however room correction can make the receiver sound better. A premium receiver like the AVR-X8500H is transparent to CD audio, so the DACs on the 9000 are great if you are using to Blu-ray music only discs with high-res for example.
X700, X800mk2 and X1100es all have the same underlying technology. The X1100es adds a LED display on the front and reportedly more noise insulation for the drive, so it's quieter. The X700 is not full width. The X1100es has analog audio out, the X800 does not. The X1100es also has RS-232 ports for automation.
Not sure why the unit doesn't have a volume control, that's pretty killer. Not sure how you would use the analog outs on the 9000 for 8 ch
It doesn't. 820 and 450 share the same video features. If I remember well the only difference is that the 820 allows manual fine tuning of hdr. The other differences are that 820 has analog mch outputs and a display while 450 has only digital outputs (hdmi and coaxial).450 lacks Dolby vision. Probably build differences.
Oh no! I have given bad advice. I was thinking about the 420 which lacks Dolby Vision not the 450. There are far more versions than I thought (I own the 9000 and bought the 420 as a gift so I knew the 400-series lacked DV).It doesn't. 820 and 450 share the same video features. If I remember well the only difference is that the 820 allows manual fine tuning of hdr. The other differences are that 820 has analog mch outputs and a display while 450 has only digital outputs (hdmi and coaxial).
So far I am testing both players, for some reason the 9000 is natively only outputting Dolby digital and the 820 is doing True HD.
Isn’t thd better than dd? Also the volume seems to be lower on 9000, I did not change the volume is this because of thd and dd difference?
Says for those codecs, please leave bitstream on and secondary set to on. Just checked and they areTrueHD is lossless. There has to be an incorrect settting on your UB9000…
After almost a year, could you please comment on your UB9000 performance?Says for those codecs, please leave bitstream on and secondary set to on. Just checked and they are
Same as the 820, but it’s not outputting thd. Tried to adjust the settings on the avr and it’s not available.
Edit: it was showing the thd on the avr and when you check playback info it showed the same but now it shows the disc is thd but the avr and pb info it’s outputting dd
I have done so above, but just to get back to the main topics. We do not know objective performance if that’s a consideration. Shouldn’t be terrible, but I did not have any desire to use analog output from the player. So I have no comments on that.After almost a year, could you please comment on your UB9000 performance?
Totally unexpected, but, as the old saying goes, "The Proof Is in the Pudding": "picture wise there was no difference", "the 820 was outputting truHD codec automatically and I was never able to get my 9000 to do it", and, IMHO, most importantly, "after repeated not blind tests using two different CD’s I noticed no difference in digital output". Ergo, the Panasonic DP-UB820 is the way to go for me, at least until the happy time I could afford the beauties of either Zappiti or MAGNETAR!I ended up returning the 9000 and kept the 820.
This is what I am explaining, I think the zidoo is really the way to go. You would need a pc/laptop or anything to burn your movies onto a 16 tb hard drive.Thank you very kindly, @MacCali
Could you please help me understand if Zappiti Reference and/or MAGNETAR UDP800 players can be employed with SSD instead of HDD inside?
Any experience using Zidoo, Zappiti or MAGNETAR, please? Please chime in, dear experts!
That would be out my reach, unfortunately... Zappiti Reference is probably in the same league prise-wise...The Magnatar setup will be basically well over 3000
I got no clue on that. Honestly if you wait until Black Friday some good sales should pop off.Thank you very kindly: I see the light now!
I as well have access to a library of Blu-ray, and DVD movies, Hi-Res Audio (up to DSD512, and PCM 768kHz / 32 bit) content located on a NAS (not in my home, unfortunately enough), and quality media player is definitely in order.
I really like what the Zidoo 1000pro has to offer (it even accepts HDMI input - bravo, very impressive!), and the only wish I have is a balanced audio out to connect media player to my balanced preamplifier... Are there any Zidoo dealers in the States, I wonder?
