Wooferhead
- Joined
- Jul 13, 2023
- Messages
- 95
- Likes
- 13
This is the interior of a typical entry-level CD Player I have.
This is a close-up shot of the transformer with a label on top that reads "NPT-1451D, ONKYO, SN2301640C, PEHH005DB, TAM M1624".
I had it plugged in to a typical wall electrical receptacle when I first received it just to test out all the buttons and functions. It wasn't connected to any components at the time, just the CD Player alone. I put a CD in it for test. Everything worked fine. It was quiet. There was no hum or any strange noise.
I then proceeded to connect the CD player to a receiver and used it only a couple times. One day, I noticed a low level hum coming from the inside of the player the moment I turned it on with no disc in it. The hum stopped the moment I turned it off. I assume it came from the transformer. I was hoping the hum would go away after a short time but it persisted ever since. The hum is not loud at all but definitely audible in close proximity, say two to three feet away.
The CD player and the receiver share a power bar with a surge protector. The power bar is plugged in to a typical wall electrical receptacle. Nothing else is on the power bar except the two components. There is a coaxial audio cable connecting the CD player and the receiver. Apart from the CD player, a pair of small bookshelf speakers is connected to the receiver.
I have attached a ferrite bead on the power cord of the CD player near its plug. Some say it would work. Unfortunately, it doesn't solve the problem in my case.
I am no audiophile and don't possess any knowledge regarding electrical engineering or electronic design. I am hoping some knowledgeable members of this forum could help identify the root cause of the hum and advise ways to eliminate it. I understand it is a rather common problem many have experienced.
Really appreciate any advice and suggestions you might have.
