Haflermichi
He has already stated at least twice he's not going to replace it.
Thanks, glancing thru didn't see that. I saw relatively cheap then buying extra gear to make it work, which didn't make much sense.He has already stated at least twice he's not going to replace it.
Absolutely agree with you there. Throwing good money after bad does not make sense.Thanks, glancing thru didn't see that. I saw relatively cheap then buying extra gear to make it work, which didn't make much sense.
Agree, especially if it only plays cds.Absolutely agree with you there. Throwing good money after bad does not make sense.
$2 worth of rubber may be all that is needed.
It's not "almost certainly" DC on the line, although that is one possibility. There are other possibilities. The HumDinger description states that it cannot stop hum from a defective power transformer:If it's mechanical hum - and it appears to be - then it's almost certainly DC in the AC line. DC blockers work, and isolation transformers work. And you're not going to find one for less than $120-150. It makes little sense to spend that when the CD player, while a nice unit, is worth about the same amount of money. But a DC blocker or Isolation transformer should do the trick.
Still the same price range, but for what it's worth I have this model:
HumDinger DC Line Blocker
The HumDinger blocks DC on AC power lines that causes transformer hum or buzz, protecting gear and extending life. It won’t fix speaker hum or grounding noise.avahifi.com
I don't need it anymore, but when I did need it, it worked great.
Loose cores or laminations are a relatively common problem with cheap transformers.Cure hum caused by a defective noisy power transformer. If the transformer has a loose core that hums the HumDinger may reduce the hum slightly, but will not eliminate it.
In comment #31 Dimitri posted a video of a very badly buzzing transformer due to loose laminations.
If there is DC on the line then other transformer powered gadgets should also buzz. Do they?
DC is a problem primarily for toroid transformers, as previous discussions on this thread indicate. EI core transformers like this one have a gap between the E and I piece that greatly suppresses saturation from small DC biases. Toroids have no gap, hence saturate much more easily in the presence of DC.
True. But if other transformers DID buzz it would lend support the DC hypothesis.IThe fact that other transformer-powered devices in the OP's home, or even in the same circuit, do not buzz tells us exactly nothing about the cause.
The table was bare. Does it make any difference?Was the table bare or was there a tablecloth ?
Perhaps I should grab a cheap old used unit to practice. Don't think I want to start with my current one.How do you think those of us with the skills got them? 95% of the time it's because we grabbed a screwdriver and started tampering. Even those of us with formal technical education developed our tampering skills by just doing it. They don't really teach tampering in school. Nothing tampered, nothing gained!
I begin to think that the hum is caused by the vibration to the entire bottom panel of the case.Does the player make the physical hum when turned on, but with the lid is removed? Often, transformers placed in that orientation will induce hum in the light gauge outer casework/lid.
Sounds like a good idea.If you have the skill to remove the lid, assuming you took those pictures, you have the skill to try putting soft, thin rubber underneath the 4 Phillips head screws that appear to be holding the transformer to the chassis.
Just PLEASE make sure the unit is unplugged from the wall, not just turned off.
A good hardware store should have sheet or strips of rubber of varying thickness. You don't need much, a few inches at most. Just enough to float the mounting tabs of the transformer. Don't crank the mounting screws back down tightly. The idea is to "float" the transformer via the compliance of the rubber.
I would try that first before spending any more money on devices.
The player is relatively new.Rather than buy extra gear, why not just replace the player?
There is no hum or buzz in the receiver connected to the CD player.True. But if other transformers DID buzz it would lend support the DC hypothesis.
Without music when the room is quiet, yes. But it is a very low level hum.Can your hear the hum from your usual listening position ?
Thanks for the suggestion. Didn't expect DC blockers and isolation transformers to be that pricey.If it's mechanical hum - and it appears to be - then it's almost certainly DC in the AC line. DC blockers work, and isolation transformers work. And you're not going to find one for less than $120-150. It makes little sense to spend that when the CD player, while a nice unit, is worth about the same amount of money. But a DC blocker or Isolation transformer should do the trick.
I would do what @Haflermichi suggested and use some rubber washers between the transformer mounting screws and the case.Without music when the room is quiet, yes. But it is a very low level hum.
I think you are on to something here.Another suggestion is damping material under the player - the vibrations may well transfer to whatever flat surface it is on and use that as a sound board.
Then there is another approach you could take.
Can you hear it when listening to music at your normal listening position? If not, forget about it - it doesn't matter. There are all sorts of sounds I can hear right now with no music playing. Light traffic noise, heating system noises. Other people doing stuff in the house. Very slight hum from the fridge two rooms way. None of it is even a slight problem when the music is playing.
