My personal fantasy (I might actually do it) is to make a mold of the side-panels and then create forged carbon fibre panels. I always wanted to try my hand at carbon fibre molding. Then replace the top panel with sheet acrylic (tinted if the VU light bleeds into the inside).Dunno why Yamaha does not offer exchangeable side panels for extra $$$: black piano lacquer, white piano lacquer, birch, teak, walnut etc.
They could also hire artists to make limited editions for even more $$$.
Pretty easy if the A-S1200 is any indication, getting the parts will be the challenge.So… I can get the black model at a nice discount. Almost 30% off. I do like the silver model, but that’s full price.
How easy is it to change out the faceplate and front knobs?
Your ears don't hear sound pressure levels like they are in reality.Sorry for my noob questions but here goes,, what does a loudness knob do compared to using a regular volume knob, why is it important to have it ?
As @UncleFungus said, VU meters are just for looks. We even have a thread entirely dedicated to VU meter pornography:Also I don't get the VU meters why do I want to look at them, just to see how much power or DB level I'm using ?? I watched A, Robinsons review and he doesn't explain those things.
Yes.Lastly would this AMP pair well well my ELAC Debut Reference DBR62 speakers ?
The louder the signal, the louder you hear bass and highs, compared to mids.
In other words, if the volume is low, the music sounds as if it has less and less bass and highs, it sounds flat, even if it technically still has the same loudness for bass, mids and highs.
This equal loudness perception becomes a problem if you like to listen to music at night, without waking up the children, music becomes flat and lifeless.
Here is the more detailed explanation:
Equal-loudness contour - Wikipedia
en.wikipedia.org
Back in the day this was solved with a loudness button that simply added bass and treble, but that obviously only works perfectly at a single volume setting. The same could be achieved with bass and treble, again, just at a single volume.
This knowledge has been lost now and manufacturers just ignore the problem, as everyone else seems to do so and still sells their wares. So for decades we had a wrong loudness, now they we don't have a loudness at all.
Yamaha solved that a few dacades ago by using a variable loudness. You put the volume setting to where it sounds best in your room, then use the variable loudness to turn the volume down to your "night level". It's brilliant, as from now on you can use the variable loudness to change the volume, but with proper equal loudness curve correction. Yamaha is to my knowledge the last manufacturer that uses variable loudness, even in their cheaper offerings like the A-S301.
Only one thing bothers me, you still move the volume with the remote, not the loudness.
Other than that, i wish everyone would do their homework and do it like Yamaha.
I think we should do equal loudness correction in the digital space, for example in a DSP or in a DAC, but nobody seems to be interested in solving the equal loudness problem really.
VU Meters: Let's See 'Em!!
If you got 'em, post a pic. Or just post a pic of your favorite VU meters. Here's a Luxman 700u. I'll post the Luxman 900u later on.www.audiosciencereview.com
Yes.
Agreed that the old school Yamaha adjustable loudness contour is better than the old switch the engaged it and the filter was slowly tuned out as you increased the volume.Yamaha solved that a few dacades ago by using a variable loudness. You put the volume setting to where it sounds best in your room, then use the variable loudness to turn the volume down to your "night level". It's brilliant, as from now on you can use the variable loudness to change the volume, but with proper equal loudness curve correction. Yamaha is to my knowledge the last manufacturer that uses variable loudness, even in their cheaper offerings like the A-S301.
From my my experience with a Yamaha WXA-50 and RX-A2A AVR, both with musicast, you don't need musicast to use Spotify, so they have "Spotify connect". Just point Spotify to the Yamaha device and it will (mostly) pick it up. From memory, you don't have to register any details with the Musicast app if you do want to use it."By the way at Crutchfield and Yamaha it says it supports MusicCast and Spotify but it doesn't say just Spotify Connect. Does that mean I would have to use Spotify within MusicCast and have to make a account with MusicCast ? The thing is I want to use the Spotify app I already have my music and the Spotify app setup like I want it. I'm new to this stuff, I bought my first receiver a couple of months ago and it had Spotify Connect so I never had to use anything else.
The point i was trying to make was, Yamahas variable loudness will solve that problem.Another issue is say I'm listening at a lower volume and using the loudness knob but the next day I want to listen to loud music I might forget to put the loudness back 0/flat. If I get this amp or any amp that has the loudness option I don't think I'm gonna want to use it.
You never touch the volume again once set to your maximum volume with the loudness flat, you change the volume with the variable loudness from then on.
It's the best equal loudness implementation i know.
That is exactly how variable loudness is supposed to work.So let me get this right, with this Yamaha I should set it at 74db with the volume button then never touch it again ? So then only use the loudness dial to change the volume ?
Always.Yes, at night.
Something like this?If I had the money to buy one of these one of the first things I would so is screw off the side panels and have a woodworker make some walnut side panels.
