They have setup their own forum. Expect less activity from them here.Wiim support on this forum hasn’t address this issue.
i put a post on their forum:but second best is going to their own forum:
Your DAC seems to be MQA decoder. Unfortunately current WiiM firmware is buggy and probably cannot deliver the MQA stream unaltered to allow the decoder to unfold it. Maybe that's why it stutters.So i have an issue. And i am pulling my hair out. Whenever there comes a song on that has MQA my Ifi Zen One Signature DAC jumps between formats and the music stutters. I have tried different optical cables. The one cable would give me a white noise when i select 192kHz and 24bit playback on the test sound. Changed the cable to the Wiim-supplied one and that one plays the 192/24bit test song fine.
Right so i have set my playback to all possible options and it still does the same.
WTF is up? What else can i try?
I discovered this same problem trying to decode MQA streams on my Gustard X18 (which is MQA-capable on optical). I reported the problem to WiiM through the app. They then rolled back my firmware to the previous version (dated 20220922), and MQA is now working just fine, with no stuttering. You can probably have them do the same, and then you can stay on that version until the MQA problem is fixed on a future firmware.So i have an issue. And i am pulling my hair out. Whenever there comes a song on that has MQA my Ifi Zen One Signature DAC jumps between formats and the music stutters. I have tried different optical cables. The one cable would give me a white noise when i select 192kHz and 24bit playback on the test sound. Changed the cable to the Wiim-supplied one and that one plays the 192/24bit test song fine.
“In theory”, it shouldn’t as Bluetooth is a lossy protocol while CD quality isn’t.I know that the suggestion can be very powerful but now it seems to me slightly better listening to Tidal hi-fi if I use the bt of my DO100 set LDAC at 44.1 / 16, compared to using the wiim via toslink. In theory, this bt setting should almost allow unchanged CD quality.
I read somewhere controversial articles related to LDAC and its 990kbps, when set to 44.1 16bit.“In theory”, it shouldn’t as Bluetooth is a lossy protocol while CD quality isn’t.
Are you using some upnp music server like Minimserver, Asset UPNP or similar? I use both and don’t have an issue playing music from my DS213j NAS.I just got the WiiM today to stream from my Synology NAS to my Rotel integrated amp (with DAC built in), via optical.
However, I am finding the WiiM app painfully slow. Sometimes it takes a whole minute for a button to respond to open a folder or doesn't respond at all.
Is this a problem with my NAS? (DS 420j, with 700gb/30,000 ALAC files and which never struggles with anything else), or just a limitation of the WiiM and its app?
Thanks for replying. I know I'm in the wrong place to say this, but I'm a novice with this. I really don't know what that means. I followed some instructions from Synology and downloaded the "media server" package and that's it. I don't know about the other things you refer to. (I did fear I would be in over my head with this stuff!)Are you using some upnp music server like Minimserver, Asset UPNP or similar? I use both and don’t have an issue playing music from my DS213j NAS.
Been a while since I used Synology’s own media server, but I fired It up again and I have no problem with speed etc when using it from the WiiM app - it appears as Synology_Ds213j under Home Music Server, and when I choose that then Music, I can then browse by folder, artist, album etc with no slowness in response.Thanks for replying. I know I'm in the wrong place to say this, but I'm a novice with this. I really don't know what that means. I followed some instructions from Synology and downloaded the "media server" package and that's it. I don't know about the other things you refer to. (I did fear I would be in over my head with this stuff!)
