WiiM Mini Streamer
Smartplug
I want linkplay to release new streamer yearly with more features. Features I’m looking forward would be a usb, preamp with bass management, parametric eq and Dirac room correction along with the features from mini would be carry over.
morillon
wiim will quickly release the pro....
the question is more when the promised services will be functional
onlyoneme
Poland
I've made some records of test RME 24/96 file on my miniDSP Flex and it doesn't look good for me. I know my DAC is not an ideal equipment as it does some internal resampling even with all DSP processing disabled. All my tests were done with master volume 0dB and all IIRs, FIRs etc. bypassed.
Original file imported:
The same file played from PC to the USB input on miniDSP using WASAPI and recorded using ASIO:
And played from Mini, fixed volume, no EQ, 24/96 toslink, recorded again with ASIO:
I doubt it could pass bitperfect test on RME at a moment...
morillon
could you redo this test by comparing the no eq mode on the mini side with the "flat" eq mode?
the eq mode has never been very qualitative ( see the comparison between flat mode and no eq on demanding music).. not necessarily can be "the idea" ...
maybe the pro will allow you to work on more interesting resolutions (see the comparison between flat mode and no eq on demanding music)..
the eq mode often poses clipping concerns that wiim tries to manage..
just that the amazing no eq "perfect bit" mode now seems to have problems like the eq mode..
ps
the few measurements with the old chromecast, no problem with clipping..
and these same measurements made in mid-September with the wiim either for that matter...
Merifon
Bulåggna
Just for curiosity, how did you play with Wiim?
The actual pictures show that there is something different in the two paths, from source to dac out, they doesn't necessarily (hopefully) mean that wiim is the guilty.
To be clear I'm not a WiiM's office defenser...
MCH
And now that the pro has a remote, a little display for the volume and we would have a terrific streamer/preamp
onlyoneme
Poland
Direct toslink link from Mini to DAC with local file played from WiiM app.
morillon
from the end of spring I had pointed out the easily observable clipping problems when measured in eq mode" to wiim. they had recognized it and had to work..
but honestly didn't interest me..
if it concerns the no eq mode on toslink, on the other hand, becomes really very annoying ...
Smartplug
Pro has the same dac as mini. I ask that on wiim forum their own website.
onlyoneme
Poland
OK, next step should be that someone with APx555 does the same, just to exclude the Flex itself.
Yes. Maybe toslink in Flex is affected, I cannot verify that. When I've used ADI-2 instead of Flex I've passed RME test without an issue. Cabling is the same, WiiM FW has changed.
morillon
me it's more stupid.
same tests:
mid-September..
no distortions
now clipping at high digital level , near 0dbfs , in non-EQ mode...
by the way passed and still passes normally with the chromecast in the same circumstances
I know my auto-translated expression is wrong
but that sounds easy to grasp, right?
(if someone can redo these measures for safety and principle?)
DeepSpace57
new update release but no Deezer support, Well done Wimm! I think they cannot manage this new Deezer API.
