It is precisely because of these "conclusions" that it is important to deal with the basics.I have done much tests with ribbon tweeter at addon on my speakers and use DSP crossover. i notice step response show best if the tweeter and the mid/bass have fewest delay together. when in stereo change the delay of both tweeter is set to 0.1 ms it have lots diffrent sound. with mono sound i hear not so much diffrence. magnitude and phase are in correlation, and influence Magnitude at a specific frequency too. both have together influence of a sound. there can not say when the result of a step response look faster it is only because FR diffrence.
Let's just look at an "ideal" loudspeaker with a fourth order crossover at 2.5kHz. So something like a standard 2-way loudspeaker.
So we get a linear frequency response over the entire bandwidth of the "ideal" drivers used.
Your procedure is now to look at the step response and determine the time peak-to-peak distance of the drivers:
Your conclusion: Wow, 0.4ms difference between tweeter and woofer peaks, the woofer is extremely slow, I can clearly hear a delay of 0.1ms** between tweeter and woofer.
** We will look at this in more detail below
However, the group delay is frequency-dependent and cannot be determined in this way.
If we consider the group delay of our standard 2-way loudspeaker we get the following:
In the above-mentioned study, it was again clearly shown that, according to the current status, it is not possible to perceive the increase in group delay caused by the allpass filter.
With for example 0.22ms group delay around 1.5kHz of our 2-way, according to the study, the perceptibility threshold in the frequency range 500-4000Hz is not exceeded by far.
Now I can already hear you saying, "That's crap, my test with the tweeter delayed by only 0.1ms clearly shows that even 0.1ms are audible without any problems. You're full of sh..." - or something like that
What does your experiment?
The 0.1ms delay means that you move the tweeter 3.5cm from the woofer (on listening axis). Of course this also leads to a phase shift.
For our 2-way speaker with the [email protected] this means a phase shift of 90°:
2500Hz --> 1/2500 s = 4.10^-4s per oscillation period (360°) --> 0.1ms delay = 1*10-4ms is 1/4 oscillation period --> 90°
With this you change the sound addition of the high and low-pass filter slopes.
For our 2-way loudspeaker this results in the following frequency response:
It would be astonishing if this frequency response dip (with a small Q, i.e. wide frequency range) would not be perceptible.
If our loudspeaker were driven with a third-order crossover and as usual one driver with reversed polarity, the effect would be even more spectacular and would lead to a perfect zero in the FR.
You see, your attempt has nothing at all to do with the audibility of group delay or "fast and slow bass".
It only shows that when a driver is delayed on one side, the frequency response changes significantly and the crossover becomes unusable... well, again that's why it's important to familiarize yourself with the basics.
