“Profoundly weird” is the exact term that springs to mind when I catch a glimpse of my aging bullocks in the mirror after a shower. But I digress . Permanent Forum Ban was issued. This particular Troll shan’t be back.
Good for you for ditching the troll, but the reference to your aging bullocks after a shower is an image I simply did not need. TMI. Way, way, way TMI!
If I listen to the fundamental (sine functions as bases) of a violin today, and the overtones of the violin tomorrow, I will not fee I heard violin sound.
Is a speaker a time invariant system?
Just like to learn. So iam surly wrong. But if its not time invariant you can not simply use fourier?No, though it can be treated as such for routine analysis. Most LTI systems are simplified versions of the real world, but the whether the simplifications matter is strongly application-dependent.
you have not answer the question. you write about time delay. I mean time delay is the result of too slow speaker speed. Can say time delays(and overshoots amd undershoots) depend on speaker speed and level changes the speaker must do. this i mean. and the result is that a mid bass woofer that reach only 6 khz -3 db(which many big not better do) have problem to reach good enough time for ITD in correlation to the other speaker when the waveform level changes of left and right speaker is diffrent at same time(which happen near allways in stereo signals. confirmed in wave screenshots)
The different step response shapes can be easily explained by comparing the frequency responses. Here is an overlay of the 2 FR curves. The more extended FR of the JBL (red curve) at the higher frequencies gives the "faster" looking step. Also, the more extended FR of the Kali (green curve) at the lower end gives a "slower" decaying step.I see clear kali is slower. maybe some strong neodyn magnets put on kali woofer can make them faster ?
https://www.sciencedirect.com/topics/neuroscience/interaural-time-differenceThe thresholds for detection of ITDs in pure-tone stimuli by well-practiced human listeners are around 10–20 μs (Klumpp and Eady, 1956; Zwislocki and Feldman, 1956; Brughera et al., 2013). That is remarkable acuity when one considers that it is accomplished with neural machinery having time constants of several hundreds of microseconds or longer. Thresholds are minimal (i.e., sensitivity is greatest) for frequencies from 0.7 to 1.0 kHz, they increase slowly for frequencies < 0.7 kHz, and they increase dramatically above 1.0 kHz such that listeners are essentially insensitive to ITDs at frequencies 1.4 kHz and higher (Brughera et al., 2013).
in this example they use only 1 speaker but intresting. in step repsonse can often see 0.5 ms delay of tweeter and mid/woofer. When have a stereo system the delay between speakers that can hear is much smaller. but how much people this can really hear need verify. this is a new link i find with many books about ITD. https://www.sciencedirect.com/topics/neuroscience/interaural-time-difference
Please read through at least the most basic background. You are misleading newcomers with statements like this.in this example they use only 1 speaker but intresting. in step repsonse can often see 0.5 ms delay of tweeter and mid/woofer.
Thanks to @Music1969 for the link.
The group delay (this is what the study is about) is frequency dependent, it cannot be determined by the time distance of the peaks in the step response!
The study confirms once again that group delay is imperceptible in 2-way loudspeakers and many 3-way loudspeakers, if reasonably designed (especially active concepts have advantages), at least in the 500-4000Hz frequency range studied - even with artificial signals.
For example, here is the group delay for a typical (real) 2-way speaker with a fourth order crossover:
Group delay >320Hz is <0.35ms, even below or at the audibility threshold for artificial signals. With real music signals, the threshold is clearly undercut.
