Sparkos SS3602 Opamp Rolling In Fosi P4
Rate this article on opamp rolling:
  • 1. Didn't learn anything
    Votes: 20 10.2%
  • 2. Not terrible
    Votes: 6 3.1%
  • 3. Found it usefl.
    Votes: 49 25.0%
  • 4. It was very nice to read it.
    Votes: 121 61.7%
Here you can download 3 samples and do a comparison
Complete bullshit what is offered there.
There are more than 2dB level difference between 1.wav and 3.wav (3.wav is louder, and even clipping sometimes).
The level difference is never ever the result of the opamp change, rather it happened either because he's completely clue-less, or worse, intentionally in order to trick people.
...he's completely clue-less, or worse, intentionally in order to trick people...
...The level difference is never ever the result of the opamp change...
Who is "he"?
You did not notice who did the recordings?
You mention difference in level, but which part of the frequency range has more than 2dB difference?
How is your understanding of differences in the sound clips done by VirtualHiFi?
These files have been extensively scrutunized and are clearly 'doctored' to make them sound distinguishable but only because of level difference and clipping of 1 file.
read onwards from here:
Who is "he"?
I had copied this comment before it suddenly disappeared, but I later confirmed that the information is accurate.
The files have been thoroughly investigated when the video was uploaded. They differ significantly.
And here is more information:
Take your pick. There's about 2.3dB level difference, but with many excursions well above that (1 vs. 3):
A little better with 1 vs. 2 (about 1dB difference with fewer excursions):
Ok, but who did change the recordings to trick "people"?
Was it done just to make people buy more expensive opamps?
Ok, but what others found to be differences is not possible due to changing opamps?
Because all opamps operate 100% identical at any electrical levels?
Ok, but it is likely that the producer of the soundfiles did changes to the frequency response around 60Hz, 90Hz, 180Hz, 360Hz and so on with variable gain in each area?
These are obviously badly done recordings, whether intentionally or not. I can't judge someone's intent from a set of files. DeltaWave is unable to compute intent from the waveforms, I'm afraid ;)
I don't know what you're asking. There were major issues with how the recordings were done. Since they were posted to prove a point about audible opamp differences, "Hell Yeah Rolling Opamps Makes Your Amps Sound Better! (Hear It For Yourself!)", the only point they actually managed to prove is that they don't know what they are doing or are intentionally misleading. From previous history with Danny, I suspect both (but can't prove this).
See the horizontal lines going through the spectrum and through the whole recording? These are not part of any music or any recording that is reproduced/recorded correctly. These are distortions lines that should not be there. Most likely the opamp(s) were not stable in the circuit, which is one of the reasons one should not randomly swap opamps without understanding what they are doing:
Your frequency chart show different levels in different areas. Why is the difference in level(+2dB) not consistent trough all of the frequencies?
This is the music which is presented in those 3 files.
This is the music found on Youtube
This is a Spectrum of the music from Youtube. Is it different from your Delta Spectrogram?
Your frequency chart show different levels in different areas. Why is the difference not consistent trough all of the frequencies?
None of us know.
We just know there are large differences that are in no way able to be caused by the opamp changes.
Nor the absolute gain differences.
It's a mess.
Not able to assign intent.
What are trying to do?
None of us know.
It's a mess.
Ok.
I got my Fosi X5 a few weeks ago after reading the review about it at ASR.
Product sound very good in my system and Fosi have more products available.
Many Youtubers are talking very positive about Fosi Products at a low price.
Several Youtubers talk very positive about changing opamps, but the price
is about same level as the product itself. Actually very expensive.
Is there any difference in sound? Yes....is stated by several Youtubers.
No is stated by measurements. I can hear differences in sound samples.
That is why I am searching some answers to make a decision.......
None of us know.
It's a mess.
As far as I know, based on the GR-Research video, the recordings were done at New Record Day.
New Record Day has been a Youtuber for many years and is still going strong.
Can I trust this Youtuber and the information he is providing?
Like many Youtubers it is always possible to find things to like and things to hate without being
at a professional technical level. But I am curious in the same way as with "Sound of Cables"
Delta spectrogram is the difference in spectrum between two recordings, not the spectrum of musical content.
Ok.
A lot of information about these files are posted by experienced people.
Differences has been discovered.
Why would anyone manipulate a file and include clipping as part
of the manipulation when so many people have tools to discover
every bit in a file?
Are differences due to
1) manipulated files
2) opamp differences
Clipping has been detected.
What can cause clipping?
The product in which the opamps were tested has a variable gain button.
If the variable gain button is lowered 3dB it will be no clipping
in the file with clipping which is presented in the video?
How about asking New Record Day to make new files with reduced gain?
Many comments on YouTube highlighting the clearly flawed sound clips have been removed or hidden since the video was posted. It does raise the question -why?
Ok.
He NEEDS to make files that are audible different.
That's his shtick.
Yes, obviously as the differences are more than 'barely audible'.
No... they can't be. The output signal is exactly the same when the opamps would be the ONLY difference (and not manipulated)
manipulation of the files. This could be intentional (which is expected) or something stupid like some auto level adjust during the 'recording process'.
WHY would one alter the gain (or volume control) when comparing op-amps.
Opamps don't alter the volume... they can't. The gain is determined by components around the op-amps.
It is unknown how and why the files were manipulated.
How about you ask him/them and do it properly... Oh right ... nobody would hear any difference between the files while Danny claims very audible differences. It would be silly if no-one could detect any differences.
I hope you are aware other people also made comparisons which are not manipulated. See if you can tell which is which.
