Old_School_Brad
- Joined
- Sep 10, 2024
- Messages
- 1,864
- Likes
- 2,601
At the very least, if you want to rename it, the science part should be marked with asterisks if you're not using technically accurate terminology.Let's just rename it to Audio Pedantic Review, then I could stop reading and half-expecting to find a discussion about technology and audio (by the way, half-expecting means 50% or 0.5, or 1/2 or 2x lower, or 2^-1, for avoidance of doubt)![]()
Is a 10p coin really 1/11 a 1 pound coin ?
1/10
0.1
Anyway, there are plenty of those "slip of the tongue" expressions that aren’t technically accurate, but people still get the gist of what’s being said.
- "Heat rises." -Not quite. It’s the hot air that rises, due to being less dense.
- "Energy is lost as heat." -Technically, energy isn’t lost it’s just converted.
- The common confusion between power and energy -like mixing up kW and kWh.
