Review and Measurements of Project Polaris HP Amp
Indeed this amp is not about measurements. It measures poorly on purpose (except for the channel imbalance).
@maty should love the 2nd and 3rd harm. distortion (which is also level dependent).
This is NOT designed to win any awards in accuracy and super measurements but is designed to flavor sound in various ways (by the customer using jumpers) and to drive all headphones under all conditions.
Yes, that's the idea. For normal listening levels it should sound 'normal with a hint of tube flavor'.
Those that don't want this should buy other amps... this will not be for them.
A feature that hasn't been tested is the output resistance which can be set to 0.1 Ohm (at least that's what I measured), 35 Ohm and 120 Ohm (an old standard) so also headphones that are designed for high output Z can be used.
The 50mW will measure poorly but for this we have a solution (way way too much power for IEM as well) in the form of a passive attenuator.
With it you can add almost 15dB to the SINAD number of 50mV measurement.
It can also be used to get a bit less channel imbalance this way with sensitive headphones.
The channel imbalance is because of the high gain and pots.
From what the seller (Jeremy of G1217) told me he buys the pots in large and hand matches them and throws out the ones that measure even poorer.
The channel imbalance of the tube designs is even worse as that is determined by the tubes entirely (no overall feedback).
Jeremy (G1217) wanted me to design a SS amp that has the same properties as a tube amp (harmonic dist).
So distortion pattern and deliberate roll-off (the middle setting is intended to kind-of mimic the roll-off from R2R DACs and the severely roll-off response is because Jeremy liked it this way with some 'shrill' headphones.
The intention for owners is to play around with all settings to get the 'sound' they want.
There aren't many amps around that let you do this as an owner. One usually gets one flavor only and there already are so many 'normal' amps around.
The tested version seems to have the 'aggressive filter' options (preferred by Jeremy). This amp can also be ordered with more conservative bandwidth settings (as I designed it) when ordering.
In wide BW setting the measured FR is 8Hz - 35kHz (-0.5dB) = 2Hz - 100kHz (-3dB) with a 32 Ohm load.
It is also available with metal top and bottom plate. Jeremy likes to see the parts, I like fully closed metal enclosures but this is too 'plain' for Jeremy. His show ;)
I would like to mention I am not part of G1217 nor do I make money of it.
I just design it for a friend (Jeremy) on his request and help him with the layout a bit.
I do service them for EU customers but do not sell nor represent G1217.
Oh ... for the nerds.... the schematics
Hi there.
I have scored a Project Polaris, second hand from Canuck Audiomart for a reasonable €251 in total, including Customs fees. In excellent condition and with a few extra Resistors and LEDs. I would like to share my experience with it, including setting up.
I have figured out, eventually, where the jumpers would go, with the exception of the Power Led, which I have only realised it was missing after turning on the Unit. In fact, I thought there was something wrong with it at first. I went back to the Manual and it became evident what that sole remaining jumper was for. Silly me!
I would prefer the LED to be RED, as I generally find Blue Leads too bright for my taste. But I saw that Trim Pot close to it and have realised that it could be usefully dimmed. I have set it to lowest brightness. I will eventually change the LED for a RED one, which the seller has also included.
As for the attenuation module, I have simply set it as Off, even though the labelling isn't too clear. I have figured out that WO probably meant Without Attenuation. And I was thankfully right.
I have set Bandwidth to High, to keep the output as extended and neutral as possible and Gain to High as well. As for Output Impedance, I have set it as Low, to ensure the widest compatibility, as well as raw power output. And by golly, is it Powerful! Even with a relatively hard to to drive Vintage DT990/600 Ohm (1985) I have power to spare and then some! I may try the Medium Gain and see if it is adequate for these and other vintage pairs in my collection. I have to say that I like to listen loud, and my ageing ears are probably contributing to that preference.
EDIT: Medium Gain proved to be plentiful for even hard to drive Vintage High Z and HIFIMAN Planar Magnetics. Very impressive indeed!
As for the Sound, it is indeed VERY good, meaty, punchy, yet still providing perfectly adequate levels of detail. I was pleasantly surprised that I couldn't ear the supposedly high levels of distortion published by Armin here. I don't doubt what he has measured, but it does not appear to be audible. Which is a big plus for me. And it pairs especially well with High Impedance, Vintage Sennheiser and Beyerdynamic!
I have other amps, with which I'm more than happy with, but for now at least the Polaris is a rather nice alternative to the others, providing a somewhat less clinical, less technically orientated performance, but very strong on Musical satisfaction. And that is the most important factor, all things considered...
You can download the manual from G1217. :)
On page 11 the jumpers are explained.
<Newbie Alert!> Please be kind : )
I'm considering Project Polaris, mainly looking for a close to tube sound.
The chain would be:
Computer (CD -> flac)] > [Atom DAC+] > [Project Polaris] > [Sennheiser HD 600]
As for music: mainly rock. From softer stuff (Kansas, Yes, ...), medium (Van Halen, AC/DC, ...), to more extreme stuff (Pantera, Megadeth, ...).
The question is about "Bandwidth options". Under this assumption: do you recommend "Aggressive" or "Mellow"?
I'm asking because I don't really understand the difference, as I said, my knowledge is limited. I'm not really interested in the technical aspects, I just want to listen to music and forget about it ; )
Thanks.
All Horizon amps have 3 user selectable bandwidth settings.
The original design allowed for wide, normal and narrow which would simulate the roll-off that occurs with a NOS DAC as some folks seem to like that.
That ended up as being 'mellow'.
The manufacturer (G1217) had some headphones that had sharp treble and found that with some of these headphones (I believe it was a Grado) he liked the sound better with a higher output R and a bit more 'aggressive' filtering (so more treble roll-off).
He named that 'aggressive', not the description of the sound.
So basically the 'mellow version' (upper plot) had the originally designed filtering where 'wide BW' and 'normal' had inaudible filtering and 'narrow BW'(similar-ish to the roll-off by NOS DACs)
The 'aggressive version' (bottom plot) had the same 'wide BW' setting (most would use it this way) and the 'normal BW' setting became what the 'narrow BW' was in the 'mellow version' and the 'narrow BW' setting rolled-off a bit more audible.
Later on Jeremy (G1217 owner) decided to offer both 'versions'.
Below the original design (V1.0).
below the 'aggressive' version (1.1)
Thank you very much solderdude for your answer.
I'm not sure I understood everything right, as I said, I don't have enough technical knowledge.
If I interpret the graphs correctly, the 'wide BW' and 'normal' filtering are outside the "Audible range". Therefore, the differences between the two versions are reduced to the 'narrow BW'.
Could we then conclude that the "aggressive version" is the preferred one, as it allows more options? (although in reality, I have no idea of its actual usefulness...)
When you own headphones that have a lot of sharp treble and no EQ then the 'aggressive' version could be an option.
The reason I developed the filters was more based on a rationalization of what the Polaris was meant to do.
The Polaris is designed to kind of emulate the sound of a tube amp but without actual tubew. It was not designed to be a 'colorless low distortion high BW amp'.
So aside from the added harmonics also some headphone dependency (3 different output R options) was included ranging from 0.2ohm to the old industry standard 120ohm with an (audible) in-between value (33ohm).
Options to vary gain over a wide range so you can drive a 600ohm headphone from a phone/dongle with only 0.5V out (E.U.)
The other (typical tube) like sound variable is frequency range.
Just like there is a 0.2ohm out I also wanted a wide BW option.
The 'mid BW' option is to mimic the upper BW of some transformer out tube amps with about -1dB for 20kHz. For most audiophiles (most are over 40) this should be impossible to tell apart.
The low BW option is so one can (sort-off) emulate the roll-off you get when listening to a filterless NOS DAC. This is audible but not feeling as 'rolled-off' treble.
Jeremy changed the filters to get more 'audible' effects, especially with his Grado.
I just picked up one of these to pair with a Grace m9xx and my treble sensitive ears love it. I've dabbled with tube amps before but didn't want to go down a tube rolling rabbit hole so I've been researching solid state options that might give me a tube like presentation minus the hassle and wallet drain. I happened to stumble upon this review and some other posts discussing the Polaris and decided why not add something this unique to my desk setup. I also love the tweaker's paradise with the jumper adjustments that allow me to adjust for different headphones. No ragrets!
it's one of my favorite amps!
I splurged for the armor variant but I also liked the see-thru version. I picked up some used Final A4000s for the soundstage qualities knowing I'd likely have my eardrums begging for relief from the hyped upper midrange/low treble tuning and the Polaris helps take the edge off of those IEMs while also supplying more than enough power. +1 for the amp flavor being meaty with good detail and the "tube-light" perk pushes it over the top to my ears.
Reactions: trl
Mine delivered today, decided to buy based on this thread. It's pretty awesome. I just have to figure out what combo of settings I like with what. The plexiglass version was definitely the right call.
