This is a review and measurements of the MacBook Air 2024 headphone output. It was prompted by a
request from
@DrSpan, as the little Mac has a very strong reputation as a headphone source. Here it is, measuring itself:
Since 2021 Apple has
supported impedance detection on the headphone outputs of its laptops, meaning low impedance headphones get more current, while high impedance headphones get more voltage. When you plug in the headphones the MacBook checks the impedance, and sets the output voltage to 1.25V if it's less than 150ohms or 3V if it's up to 1kOhms/. Above that it assumes you're using it as line interface and sets the voltage to 1V. It only does this check when you physically plug in the jack, which caught me out a couple of times in testing!
So the first question is does the impedance sensing work? It absolutely does, and the voltages are superbly accurate at 1.00V (4.7kOhms) and 1.25V (30ohms), dropping a tiny bit from spec to 2.97V at 300ohms.
The second question people have is how much power it can actually deliver? I won't make you wait, it delivers exactly to spec into
300ohms at 29mW, so essentially no voltage drop. Into
30ohms I got 48mW against an ideal of 52mW, and into 15ohms the gap widened a bit more with
85mW against an ideal of 104mW.
OK, let's do some graphs! The measurements were taken with a Cosmos ADCiso and a resistive dummy load. The ADC was running at 96kHz/24bits, with the laptop outputting 44.1kHz/float32, which is the default. The laptop was connected to external power via a thunderbolt hub. The headphone output itself is a 3.5mm TRS jack, i.e. unbalanced stereo.
Here's the best SINAD I could get, which was at 0dBFS output into 30ohms, delivering a
SINAD of 97.9dB:
Frequency response is ruler flat to 16KHz, then drops about 6dB by 20KHz. If you change the output sample rate in "Audio MIDI setup" then you get the same result, e.g. the drop starts around 44kHz when using a 96kHz sample rate. The good news is the filter is steep and clean with no rise in noise after. It does look quite tailored, but I didn't get into impulse tests:
Here's THD+N vas power at 15, 30 and 300ohms:
And here's CCIF IMD (19 and 20kHz tones) at 30 and 300ohms:
The multitone distortion is very clean - I've overlayed all three impedances but they are pretty much the same:
Crosstalk was about -50dB. This was measured by driving one output at 0dB while measuring the other, so they share about 1m of cable before being split out for measurement:
At 50mV into 30ohms (with the Cosmos Scaler boosting the signal to about 1V into the ADC) I was able to get a SINAD of 89.1dB, which is less than the 95dB L7 Audio Lab measured but I think their measurement may be A weighted, and they have an APx555:
In conclusion definitely 5 quokkas from me! There's simply no reason to use an external headphone amp with any MacBook made since 2021 unless you have demanding headphones. It's not nearly as good for power as a good desktop headphone amp, but it is better than popular interfaces such as the Scarlett 2i2.
