I have to be honest: I'm probably not the target audience for this kind product. And I would assume that most ASR users aren't. That being said, I couldn't resist making a quick comparison to the
SMSL SH-9 on my desk:
| Euphony | SH-9 |
| THD+N (1 kHz) | 104 dB | 120 dB |
| SNR @ 50 mV | 67.6 dB | 88.2 dB |
| Power @ 300 Ohm | 339 mW | 226 mW |
| Power @ 32 Ohm | 689 mW | 1700 mW |
| Output impedance | >>1 Ohm | <1 Ohm |
| Channel imbalance | >0.5 dB below -22 dB | Flat to at least -75 dB
(resistor ladder) |
| Balanced input | No | Yes |
| Balanced output | No | Yes
(but wired unbalanced) |
| Gain switch easly accessible | No | Yes |
| Shiny casing | Yes  | No |
| Price | ~1400 $  | ~250 $ |
I don't know. There's a lot more green (= good stuff) on the right side of this table. It doesn't really make sense to me to construct a flashy casing, only to fill it with sub-par electronics. The performance at 50 mV is egregiously bad for the price. Amir was very kind to not show
the usual bar graph for performance comparisons at 50 mV - the Euphony would be in the lowest 20% of all devices tested to date. 67 dB is likely bad enough to actually hear noise when using IEMs or sensitive heaphones. That's probably not the main use case for an amp like this, but still very dissapointing.
