CHORD Alto Headphone/Power Amp Review
Rate this headphone and power amplifier:
    Votes: 245 65.0%
    Votes: 104 27.6%
    Votes: 22 5.8%
    Votes: 6 1.6%
This is a review, listening test and detailed measurements of the CHORD Alto "Professional" hybrid power (speaker) and headphone amplifier. It was sent to me for testing by Bloom Audio and costs US $4,320.
CHORD's iconic design elements work quite well in this package, giving it an elegant while strong feeling. The volume control feels great especially with that dent in there for your finger. Four headphone outputs are provided but the balanced ones are just connectors and don't provide more power (see measurements below).
Then we get to the lightshow buttons which are as always, a step back from ease of use. It is so bad that the company provides a cheat sheet for you to use to decode which light means what. Fortunately they left light is dedicated to input and right one, to output so that part you don't have to guess. The center globe rotates and again thankfully, that doesn't do anything. You just push it in to power cycle the amplifier.
Sequential cycling worries me for a professional product. Imagine cycling to speaker output at high volume when you wanted headphone with the client present.
Back side shows the standard connections but with inclusion of recessed banana jacks for speaker output:
Chord Alto Headphone Speaker Professional XLR Balanced back panel RCA power supply review.jpg
The speaker outputs had a tape over them and said to read the manual before using. I read the super brief manual but found no warnings about using them so don't know what that was about.
As you see, the power supply is a very high current 12 volt unit. It comes with super stiff AC cable and cable that connects to the amplifier. Fortunately the amp is heavy enough to not be tugged by it but still, it adds annoyance to having an external power supply to begin with.
Since this is a professional device, I limited my testing to using XLR input.
If you are not familiar with my amplifier measurements, please watch this tutorial:
[And subscribe to the channel :) ]
CHORD Alto Headphone Amplifier Measurements
As usual we start with our "unity gain" amplifier test where input and output voltages are the same:
I was disappointed by the spray of distortion products which likely indicates low amount of feedback. The spec is better than what I show but lacks detail to know if it is a comparable test. As is, performance is very much on the low side when it comes to noise+distortion:
As noted, I tested 4.4mm pentacon output as well and it is the same. Here is the noise performance:
Good with unity gain but residual noise is too high for any sensitive headphone or IEM:
Frequency response is nice and flat:
Chord Alto Headphone Speaker Professional XLR Balanced frequency response Measurement.png
Now we get to good part: this HP amplifier produces a ton of power!
Chord Alto Headphone Speaker Professional XLR Balanced Power 32a ohm Measurement.png
Chord Alto Headphone Speaker Professional XLR Balanced Power 300 ohm Measurement.png
I have probably only tested one or two amplifiers with this level of output. Noise and distortion are compromised to get there but we get something useful for that.
Channel balance is excellent for an analog control:
Chord Alto Headphone Speaker Professional XLR Balanced Power channel difference Measurement.png
CHORD Alto Power Amplifier Measurements
I set the output to speakers and volume to maximum:
We again get the spray of distortion. SINAD of 73 is some 7 dB worse than the average for all amplifiers tested.
Noise performance is excellent for a power amplifier (needed for the HP output to be any good):
Chord Alto Headphone Speaker Professional XLR Power Speaker SNR Measurement.png
Frequency response is load independent as one would expect:
Chord Alto Headphone Speaker Professional XLR Power Speaker frequency response Measurement.png
Crosstalk is disappointedly high for class:
Chord Alto Headphone Speaker Professional XLR Power Speaker channel separation Measurement.png
Distortion rises with frequency:
Chord Alto Headphone Speaker Professional XLR Power Speaker Multitone Measurement.png
I think this is the worst 19+20 kHz intermodulation distortion results I have seen, since I started running this test:
Chord Alto Headphone Speaker Professional XLR Power Speaker 19 20 kHz intermodulation distorti...png
Power output is modest but more or less matches the spec:
Chord Alto Headphone Speaker Professional XLR Power Speaker Power 4 ohm Measurement.png
Chord Alto Headphone Speaker Professional XLR Power Speaker Power 8 ohm Measurement.png
Once again noise and distortion are very high for the class.
At this point, I went into measuring power at 1% THD. For this test, I have to let the analyzer push the amplifier into clipping so it can then back down and find the 1% THD level. I typed in 4 volts for output. This immediately cause the ALTO to shutdown which is not unusual for some amplifiers. Alas, the amplifier would no longer output anything. Its front panel was working but no matter what I did, there was no output. I went back and tested the headphone output and it too was dead. I disconnected the power and cycled it a couple of times but it would still not work. I let it sit overnight and this afternoon, it started to work again:
Chord Alto Headphone Speaker Professional XLR Power Speaker max burst peak Power 4 ohm Measure...png
Chord Alto Headphone Speaker Professional XLR Power Speaker Power 4 ohm 40 Hz Measurement.png
I was too afraid to run reactive and regulated ("FTC like") tests as I wanted to listen to the unit. But did run the frequency power sweeps:
Chord Alto Headphone Speaker Professional XLR Power Speaker Power 4 ohm vs frequency vs distor...png
The increase in distortion is almost linear with frequency which indicates little to no feedback.
Soft power on/off produces strong pulses which are likely audible on speakers:
Chord Alto Headphone Speaker Professional XLR Power Speaker Power on off noise Measurement.png
CHORD Alto Headphone Listening Tests
I connected my RME ADI-2 Pro interface's balanced output to the Alto and plugged in my everyday Dan Clark E3 headphone into it. The Alto drove the E3 harder than any amp I have used with it b before. Well before max volume, the loudness become intolerable while the sound remained clean without any distortion. Dynamics as you can imagine were superb with nothing to complain about.
I watched a video where it was said that the Alto was designed to drive multiple headphones. So while I had the E3 still plugged in, I also added the Audeze LCD-XC to another socket. The Alto drove both of them with ease and once again producing a level of power that was both pleasing and dangerous! :)
There have been amplifiers where company also recommends their use for headphones. But the Alto is the first one I have tested that claims that capability from start. Benefit of this approach is that there is the potential for tons more power which the Alto deliver son in spades. Both objectively and subjectively, you basically have unlimited amount of power to drive not one, but two or more headphones simultaneously. While you don't have independent control over each volume, I can imagine this being useful in a studio where the same headphone is used for multiple people to listen at once.
The compromises are kept low with distortion that is too high for my liking. Noise is good enough for most headphones but not IEMs.
I am not sure of the usefulness of driving speakers with it given the modest power output and potential issue with protection circuit. But I guess it comes for "free."
The cost is of course way up there. So you would have to value the looks, the brand, support, etc. and decide if it justifies its cost.
I am going to recommend the Chord Alto on the basis of its copious amount of power. Nothing ruins the performance of an amplifier more than when it runs out of juice.
My appreciation also goes to Bloom Audio for providing this sample for test.
EDIT: Video review posted:
Reserved for @AdamG to kindly post the specs.
Manufacturer Specifications:
Link to additional details and webpage:
So... put a low-power "okay" speaker amplifier into a box, call it "headphone amplifier" and you can charge 4K for it?
Recommended?
What a pile of overpriced junk!
Thank you for the distortion vs power vs frequency measurements, Amir.
I think they're always really telling, and they tell a bad story here.
Nick
The burning question here is whether Chord copied the lighting show from the first round of "Squid Game"? Aside from that, isn't it great for them to offer a 45 wpc speaker amp with the noise and distortion characteristics of a Behringer A500, and marry it with that very powerful headphone amp with early 2000's level Sinad? All for only $4230. Well at least they're not asking 4,230 Guineas for it.
A lot of power, and while my Topping A70 Pro doesn't have quite as much, I've never had it run out of steam, and it costs around one tenth the price with a Sinad exceeding 120 db. Looks better too. Just seems, at best, like a piggybank panther to me. But since that option was not available, gotta vote Headless Panther.
Thanks for this review, Amir.
According to your measurements - 6.079 W at 32 Ohm and 871.7 mW at 300 Ohm, this has less power than the Topping A70 Pro - 8.22 W at 32 Ohm and 977 mW at 300 Ohm - and L70 - 6.95 W at 32 Ohm and 918 mW at 300 Ohm. The A90D also has about as much power - 6.036 W at 32 Ohm and 925 mW at 300 Ohm. The VMV P2 also has similar power at least at lower impedances - 5.988 W at 32 Ohm and 617 mW at 300 Ohm. All of them are significantly more affordable than the Chord - one with a price over ten times lower - and are offer vastly superior distortion and noise performance.
Before the above mentioned amps were reviewed, you wrote about the Burson Soloist 3XP, which is similarly powerful but also has high noise and distortion like the Chord.
To borrow a phrase, Burson Soloist 3XP is all power and little fineness. Not objectively anyways. If you have very inefficient headphones, it can provide power that few headphone amplifiers in the market can provide. At anything lower, you can get far better performance for much less money.
I can't recommend the Burson Soloist 3X Performance unless you have a niche application of needing its power.
What is the difference that now the Chord gets a recommendation while the Burson did not even with fewer alternative and vastly superior options reviewed then?
Not competitive w current offers from Topping, SMSL, Neumann (their amplified speakers)…I have learned from ASR. Unless you fall for its looks and happy to pay a premium for post-industrial design (they remind me of Jean-Claude Forest comic books), there are better measurement and better prices out there.
I love the external Topping like power brick , don't like anything else . My old Belles pre amp could drive speakers too , never tired it , why would you.
Seems like a waste of time and money when normally Chord are just a waste of money .
I can thoroughly recommend 1906 , the beer , liquid bread, a absolute delight . This device costs many many beers , seems ridiculous.
Other value metrics are avaliable.
Edit , thanks Amirm for the excellent review, brilliant effort my old friend, it's important we see products like these under the microscope . I'm glad you enjoyed the power !
Alto is substantially better than Burson:
I am not familiar with the market for the Chord Alto. I am saddened for any users for whom it was their best option.
I’m stuck thinking how much kit and other stuff I could buy with the $4300+taxes. Slap on a Professional Label and times by 10. Don’t forget to add the 2 year extended warranty for an additional $400 for a grand total of $4700+ taxes. :oops:
Thank you for the very thorough and comprehensive review Amir. You have been crushing it lately with multiple back to back reviews and YouTube Review Videos to boot. It’s Saturday night in case you forgot what a weekend is. Sleep in tomorrow and take a breather Sir. :cool:
But still substantially worse than the Toppings and the VMV which were not reviewed before the Burson.
??? Topping got my highest recommendation:
The Alto got one notch lower.
Then why it rotates? Is it an anti-stress? (well, if you see these measurements after spending 4.3k I guess you need one).
Anyway I can't understand how it works... How do you select inputs and outputs? Are the lights switches? But then you must cycle through... sorry i'm confused o_O
But given the utter nonsense of this device at its price I'm at least sure that that thing above the red light is a reflex port :cool:
[EDIT]
Ah ok, it's not an hole, but the remote sensor.. So it has a remote, and there you can directly select sources and outputs. Now all makes sense... at least on the usability side:
Input selection Press the input button sequentially to cycle between XLR (input button displays blue) or RCA (input button displays red). Alternatively use the remote control to select the input: Line 1 for XLR, Line 2 forRCA.
Output selection Press the output button sequentially to cycle between speaker (button displays red), headphone (green) and XLR (blue). Alternatively use the remote control to select output: TP-01 for headphone, TP-02 forspeaker and TP-03 for XLR
more or less...
:rolleyes:
