Yes ! Works just fineSL-1500C, yes? If so, are you using the VM95ML with the built-in preamp?
That stand as absolutely silentGoodstuff, even better if you replace that singing metal stand.
Is it “known” like fuses, cables, and capacitors are “known” to make a difference? Or is there actual data?the impact of support is known to be very sensitive..you should in your particular case listen to this advice........
Or, in my case, when you put the turntable on a pine chest of drawers right next to the RHS speaker.It can be severe enough to cause feedback, though that is usually in situations where PA systems are involved.
I mean you can get feedback just over the air, no transmission through resonances in supports, so I’m sure it is true at some level.No, it's quite measurable and also audible. It can be severe enough to cause feedback, though that is usually in situations where PA systems are involved.
Out of curiosity, what damping did the turntable have built in?Or, in my case, when you put the turntable on a pine chest of drawers right next to the RHS speaker.
The pine chest made a lovely resonant sound box causing low frequency feedback. Solved by putting half of a solid oak door, under the turntable, with sound damping material between the door and the chest, and between the door and turntable.
slightly soft feet.Out of curiosity, what damping did the turntable have built in?
It's a good equipment.
If you don’t hear a problem, don’t worry about it. There are lots of things that make a difference in theory or measurement but are not readily audible.It’s totally quiet, I can play it soft or loud, no noises, I can walk/bounce on the floor or drum in the shelf with my fingers, nothing. The turntable has very pliable feet and it weighs about 35-40#.
Also good looking TT,
It is a great phono stage and Dan Wright's craftmanship is top notch. His new PS 9.0 is a more modest phono stage but also an exceptional performer. Possibly as good as the PH-150 (depending on options) at less than half the cost?Awesome post, I use the very same phono pre!
