- Joined
- Jun 5, 2016
- Messages
- 3,440
- Likes
- 5,867
Neumann LH 65.What speaker stands are you using for your desk setups? Currently, mine are resting on foam isolation pads, but I'm searching for a solution to raise them closer to ear level.
Why is the white one more expensive on Thomann ?
I sure did but thanks for the idea!Stupid question, have you tried the "ground lift" switch button ?
It was user error. Had a cabling whoopsie.How is your adapter wired? With ground lift active there really should not be hum in the system when everything is done right.
What is your experience with studio monitors and why you went that way? I can't imagine them sounding that different, I owned both of them and both are very good, it's either some strong bias or user error. Do you have any measurement of your in room response? Did you calibrate them with MA1? Why are you comparing digital monitors to analog model, instead of 8330?On the measurements looks phenomenal but I’ve bought one for trying and after a week I only can say that (at least for me) is overestimated.
Nothing sounds so bad, but nothing sounds so good neither. “Boring” is the word that comes to my head but is more like “predictable”
For mixing is sure that will show a lot, but I compared with Genelec 8030 (which is quite flat also) and the last one is quite more enjoyable while showing more information at mid range.
Bass is quite good, no complaints about it as Amir said.
Waiting for a streamer with spdif output, to check how it performs with its direct internal conversion, just in case this “greyness” is due to mixing two DACs and one ADC blurring a little bit mid and high frequencies. A violin sound horrendous for example, never heard something so bizarre. Piano not so bad, voices quite unnatural (but there the Genelec is spectacular, so is unfair to compare).
You can rent one for six months for 155AUD: https://www.musicorp.com.au/pro-aud...-monitor-alignment-microphone/212188-1959098/There are good sales on these in Australia right now and I'm about to place an order from a local Sydney audio shop. The issue is that the MA1 microphones are still super expensive and not available for renting. My room setup is far from ideal so I'm desperate to get hold of one to do room adjustments.
Does anyone have any advice for getting an MA1 short term in Australia without purchasing outright? If any fellow Australian users are in here and have an MA1 they're comfortable sharing, it would be most appreciated.
Is everyone else just buying MA1's to keep? I don't know how useful they would be after the calibration is done. Would there be any point using one as an "upgrade" over my Blue Yeti for conference calls?
Thanks Static!You can rent one for six months for 155AUD: https://www.musicorp.com.au/pro-aud...-monitor-alignment-microphone/212188-1959098/
Still not cheap but better than the 400AUD for a new one.
Edit: here's another rental service: https://sounddevices.com.au/collections/monitors/products/neumann-ma-1-measurement-microphone
Might be even cheaper.
You need the MA 1 mic unfortunately.Thanks Static!
I'll look into these. Is an MA1 necessary to run Neumann's room adjustment software? Would any measurement mic be compatible?
You don't NEED it but you need the serial number and MA1 uses the corresponding mic correction.Thanks Static!
MA1 is really simple to use? Connect your mic, tell them which speaker sits at which position and put the mic on a few positions in the room. And you need a connection to your speakers, a switch and LAN cables is actually pretty simple cause you don't have to configure anything.Why don't every brand has a simple solution for noons like me like GLM is beyond me
Is like just to connect a mic , click a button and be doneMA1 is really simple to use? Connect your mic, tell them which speaker sits at which position and put the mic on a few positions in the room. And you need a connection to your speakers, a switch and LAN cables is actually pretty simple cause you don't have to configure anything.
Where are your problems with that procedure? How could it be easier?
I would say Dirac is more complicated as MA1. Sonarworks is a little easier cause it tells you if the positioning is right.
You can't have a proper calibration that way! You need more as one measurement point to do a room correction.Is like just to connect a mic , click a button and be done
