Measuring 2-channel Buckeye Purifi Amplifier Performance
So, as am updating my amps, here is some visual proof for the cause of the slight distortion rise that was seen when Amir tested the Buckey 3 channel amp...
Note that the above graph is just THD vs Power. I thought this would be more interesting as the ferrous content primarily introduces distortion. For a preview of updated SINAD vs Power results, see below...
Note the expected hockey stick graph as the distortion rise has been reduced. :)
It might sound naive, but what are ferro and non-ferro tabs?
In this case, the original binding post tabs had steel content, the new ones are brass.
Are the graph labels reversed? Shouldn't the non-ferro tabs give lower THD?
Thanks good point, the label UI is tricky here, will fix. :facepalm:
