Measuring 2-channel Buckeye Purifi Amplifier Performance
Rick Sykora
Rick Sykora
Stow, Ohio USA
So, as am updating my amps, here is some visual proof for the cause of the slight distortion rise that was seen when Amir tested the Buckey 3 channel amp...
Note that the above graph is just THD vs Power. I thought this would be more interesting as the ferrous content primarily introduces distortion. For a preview of updated SINAD vs Power results, see below...
Note the expected hockey stick graph as the distortion rise has been reduced. :)
AndreaT
Commonwealth of Massachusetts
It might sound naive, but what are ferro and non-ferro tabs?
Rick Sykora
Rick Sykora
Stow, Ohio USA
In this case, the original binding post tabs had steel content, the new ones are brass.
Rick Sykora
Rick Sykora
Stow, Ohio USA
Are the graph labels reversed? Shouldn't the non-ferro tabs give lower THD?
Thanks good point, the label UI is tricky here, will fix. :facepalm:
AdamG
Debunking the “Infomercial” hawkers & fabricators
Moderator
Reality
