I am curious as to which sub-bass heavy tracks you use in your tests?my "speaker killer" tracks with sub-bass response down to 20 Hz
I like this better than any monitor I have tested with smaller woofers. It just has more power, dynamics, and bass extension. The frequency response error is easily fixable in M-Audio whereas I can't add power to the smaller monitors. At the prices that are around, it is an incredibly bargain.Other speakers I considered are Adam T7v and Kali LP6v2 but I can’t tell if they’re worth the 80€ premium over these M-Audio speakers
Well, the distortion profile looks less critical than on most cheap competitors. It never exceeds the main tone which is probably why it doesn't sound too distorted in the sub-bass. And in the most cirtical area from 2-5kHz THD is about -45dB (at 96dB) which is pretty decent for any (active) speaker.That's a lot of bass distortion for an 8" woofer!
As I reported, it is essentially silent. With my ear right next to the tweeter, I could barely make out some high frequency hiss. Much lower than many other monitors I have testewd.One thing I would be somewhat worried about is noise - it's an older design with a very high input sensitivity, that's not usually a good sign.
Hi Amir,I like this better than any monitor I have tested with smaller woofers. It just has more power, dynamics, and bass extension. The frequency response error is easily fixable in M-Audio whereas I can't add power to the smaller monitors. At the prices that are around, it is an incredibly bargain.
I actually use the Kali LP6 with rpi and Camilla DSP. Fairly happy except that the DSP introduced delay that's been driving me nuts. Only use it for music now, not for any video.Raspberry Pi with DAC board running moode and Camilla DSP.
This allows for some speaker corrections and also mixing to mono because I only need one speaker
Probably, another question is quality of components and overall life expectancy.As was remarked before, in Europe the speaker seems to be available and about 100-150€, so with a little bit of EQ a really cheap and nice setup for a desktop environment, or even a listening room. Amazing value for cost, it appears that above diminishing returns kick in badly (Neumann, Genelec, Adam etc.).
Yes but you might create a ground loop, a DI box or similar might be necessary (Behringer HD400 for example).Do they work with TS to RCA cables?
Just read the manual and they say you can use XLR, TRS or TS.Yes but you might create a ground loop, a DI box or similar might be necessary (Behringer HD400 for example).
I used a Raspberry Pi with CamillaDSP connected via USB to my PC for a while and didn't have any latency issuesI actually use the Kali LP6 with rpi and Camilla DSP. Fairly happy except that the DSP introduced delay that's been driving me nuts. Only use it for music now, not for any video.
That was yesterday, sold out @ thomann already.. I could swear ASR pulled the trigger ..these mass dealers should send regular fees to ASR damn it!I don't see it's discontiued actually, not on the M-Audio site, and not in stores in europe. And here it's very cheap: https://www.thomann.de/be/m_audio_b...LCJjdXJyZW5jeSI6MiwibGFuZ3VhZ2UiOjJ9&reload=1
