You forgot to mention V8 pick up trucks and utesFine for small UK rooms and low powered amplifiers, but not big rooms, big-ass power amps and American/Australian tastes in level, music, beer, friends and BBQs.
If I bought these, I'd cross them over at 150 hz to my two SB 2000's and use the PEQ in JRiver together with DLBC to make everyone work and play well together. Bet I could get them to hit 105 db doing that.
If I decide to upgrade from my LS 50 Metas, these are an option, along with the Sierra LX, and the Sointuva AWG.
Are you really asking that or do you just want to express your opinion?What’s the point of getting an 8000 euro speaker that can’t even clear 96dB full range.
Are you sure about this? My LS50 Wireless II certain does volume with my TV over eARC, I thought that was part of the eARC standard. I'm seeing reports elsewhere online the LS60 does volume over eARC.Also eARC is supported but there is no volume control ... That's fine if you have an AVR but it does not work as expected if you want to connect your TV directly to the LS60.
Read that before, but what is the point?I hope Amir will be able to take them for a spin as well.
Same over here. On top of the TV remote, you can use th speaker's remote and the app volumen selector.Are you sure about this? My LS50 Wireless II certain does volume with my TV over eARC, I thought that was part of the eARC standard. I'm seeing reports elsewhere online the LS60 does volume over eARC.
Yes, it works fine for mine.I will try again. The manual says it should work.
if the ls60 don't give loud enough spl why u suggest a worse speaker for the taskThen just buy an LS50 meta.
Yes. And that pretty much always has been the case when Erin /Armir measured other KEF speakers as far as I remember. R3, R5.Wow, Kef’s anechoic spin is remarkably close to Klippel NFS spin.
That’s gives me more confidence when looking at Kef’s published/posted spins.
if the ls60 don't give loud enough spl why u suggest a worse speaker for the task![]()
If you highpass the ls50 at 150Hz it can definitely give 96dB.
Yes, and if one DIY two tower subwoofers the same hight as ls50 with stands , one can cross even higher in frequency , maybe 200 Hz ?If you highpass the ls50 at 150Hz it can definitely give 96dB.
Not really.
Quote Amir LS50Meta „…. Looks like distortion in from 200 Hz and up is excellent but down low, even at 86 dBSPL, we hit 100% THD. Unfortunately I don't have comparable measurements for LS50 as that was a long time ago before I standardized this way….“
Thread 'KEF LS50 Meta Review (Speaker)'
https://audiosciencereview.com/forum/index.php?threads/kef-ls50-meta-review-speaker.25574/
Do you not understand what 'highpassing at 150Hz' mean?
Can’t you read Amir’s data at 96dB at 200Hz and up?
@96dB it appears to reach 100% at 50hz. At 100hz it's still below 10%. So a 150hz crossover should support 96dB without crazy distortion.
