Sorry. They are woofers. Only if the coax was really full range would they be subs (and tiny ones at that).Ohhhh, don't tell me that...
Where did you find them? Can’t find any pictures other than the Royal Blue. Please link.
You don’t have to post them, just tell me how to find them .Our hosts here aren’t keen on us breaking Kef’s embargo. Sorry.
It does solve the biggest real problem of the LS50 though which is that 5" with a hole in the middle is a midrange that is struggling very hard to play the part of a woofer even with a sub, let alone without.Sorry. They are woofers. Only if the coax was really full range would they be subs (and tiny ones at that).
There definitely aren't any photos on this forum page: https://forums.stevehoffman.tv/threads/kef-ls60-towers-incoming.1143615/page-2You don’t have to post them, just tell me how to find them .
I’ve already ordered a pair of Blue ones, but are having second thoughts about the colour.
or pounds... or euro... or yuan...60th anniversary...
So $60000 or $6000.
You're not fooling me, Ron. I know a Mirage M1 when I see it.Official image, LOL:
ThanksThere definitely aren't any photos on this forum page: https://forums.stevehoffman.tv/threads/kef-ls60-towers-incoming.1143615/page-2
(If you don't scroll down, sarcasm doesn't often translate to text, but italics help)
My guess as to drivers is the coax unit from the r-series, maybe with the meta stuff, maybe not. -- Though it could be the blade unit.
(Leaked photos show too small of a surround to be anything from the prior LS-series)
Then 4x "Force Cancelling" mid-woofers of some sort. Ported most likely, knowing the blades.
The woofers will probably be 5". Something smaller than the blade 2, but once again it could just be the blade 2 drivers.
If they do end up being blade 2 drivers, they'll only be offered in an active configuration, as to not cannibalize the blade 2 sales. If they are R-series + meta drivers, then it may be offered without amps, but that would probably undercut the blade 2 too much. Of course, option 3 is they do blade drivers, but without the meta stuff. That would allow for product segmentation and a competitive price.
As for the price (pair),
LS50W2 - $2800, KC62 - $1500
Blade 2 - $28000, R7 - $4500
Somewhere more than LS50W2 + KC62; way less than Blade 2, but probably higher than R7 (due to amps)
$6000 sounds about right, especially considering the fancy box design, active electronics, and shipping cost associated with a tower speaker. Though it would be nice if they would offer a cheaper, passive option... but then the R7 would be pointless.
Since both the LS50 2nd gen and LS50W2 already came with Meta (and each speaker they released since...), there's no debate about the newcomer. It also will...My guess as to drivers is the coax unit from the r-series, maybe with the meta stuff, maybe not.
What are you talking about? LS60? Not a chance...I’ve already ordered a pair of Blue ones, but are having second thoughts about the colour.
Yes; LS60, havent seen them and dont know the cost. But i talked to the importer, so a pair got my name on it, when they get here. Dont know when they do, but some time this summer.Since both the LS50 2nd gen and LS50W2 already came with Meta (and each speaker they released since...), there's no debate about the newcomer. It also will...
Also, why would KEF use R-series drivers when this exists in the same lineup?
2-way vs 3-way.Also, why would KEF use R-series drivers when this exists in the same lineup?
Yep. Honestly, it doesn't make that much sense when using an active/DSP controlled crossover design. Sure, the driver's surrounding differ when asking for more low end output from the dual concentric. Yet, it will be "Meta" anyway.2-way vs 3-way.
It’s a totally different design philosophy: you can optimize for efficiency and midrange distortion vs bass extension. That needs a less powerful amplifier as well and leaves more enclosure volume for the basses. That it will be Meta is basically evident by now.Yep. Honestly, it doesn't make that much sense when using an active/DSP controlled crossover design. Sure, the driver's surrounding differ when asking for more low end output from the dual concentric. Yet, it will be "Meta" anyway.
There things are definitely not marketed for home cinema.Because with film sound, a subwoofer will be important.
Not me !!!!Is everyone here sure it doesn't have active subwoofers built in? Can the pros tell from a photo? Then I wouldn't wait any longer and buy the LS50 with subwoofer. Because with film sound, a subwoofer will be important.
The LS50 has weak bass even with a sub unless you cross that sub over extremely high, and even then...there is a reason the 5" uni-q is crossed at ~400hz in Kef 3-ways.Is everyone here sure it doesn't have active subwoofers built in? Can the pros tell from a photo? Then I wouldn't wait any longer and buy the LS50 with subwoofer. Because with film sound, a subwoofer will be important.
