JBL HDI-3600 Speaker Review
Robbo99999
Bamberg refers to vertical MTM 2-way construction which was pretty popular in ´90s. those really do have problems with vertical directivity!
more about these variations, a modular diy speaker series by Zaph http://zaphaudio.com/ZA5/
That looks like a great resource to learn from, I read through it & also bookmarked it, on that page they don't talk about the exact same config as that being reviewed here though: 3 woofers on the bottom & tweeter on top.
thefsb
I dislike it when different tower models have different tweeter heights, as if the flagship has it too high, then you are out of luck unless you angle it down.
What's to prevent placing the tweeter lower in the array of drivers? It's below the mid-range driver in the Ascend tower.
Promit
The "dust" problem is even worse with guitars.
I think I have eight or nine guitars here and only one is gloss. All of the others are satin finish front and back. Better to keep clean and better to play.
Frank Dernie
Oxfordshire
The crossover at 900Hz doesn't behave the same way as the crossover at 2000Hz then? I'm thinking because if it did behave the same it would eventually hand off all of the frequency response to the "next speaker up", does the low bass woofer never fully hand over to the 2 mid range woofers, is that the crucial part of 2.5 way?
Typically this sort of layout uses one of the larger units for bass and mid and the other two for just bass, so the top one will cross over to the tweeter at 2kHz and the bottom two join in at 900 Hz.
This is the way these types have been for decades.
Robbo99999
Thanks yeah, I'm new to the audio scene, so have knowledge gaps, some previous posters cleared it up for me already though along with graphs, gotta love graphs!
ctrl
.de, DE, DEU
If we compare the JBL with the Buchardt (only) in terms of possible problematic frequency ranges, the Buchardt performs better than the JBL.
I am surprised how well the score highlights this difference.
It also makes clear what the Buchardt gets in return for the high harmonic distortion, low bass that puts a full-fledged floorstander in its place (only in terms of low frequency response).
The badly made transition from compression driver to waveguide at 10kHz is in this price region unusual. Most of the time, a slump in frequency response cannot be completely prevented, but often it is possible to shift it to higher frequencies (e.g. by using a smaller throat diameter, special transition area between compression driver and waveguide to avoid interference, ...).
Since the ER curve also shows this dip, it should actually be perceptible.
Buchardt
SCORE: 5.5
SCORE w/ sub: 7.6
JBL
SCORE: 4.9
SCORE w/sub: 7.1
edechamps
London, United Kingdom
If we compare the JBL with the Buchardt (only) in terms of possible problematic frequency ranges, the Buchardt performs better than the JBL. I am surprised how well the score highlights this difference.
According to the @MZKM breakdown it's due to their NBD_ON and NBD_PIR scores. You can use the early preview of Olive score calculation in Loudspeaker Explorer to get more insight on that:
It's clearly the 10k dip that's killing the JBL as far as the score is concerned.
Jon AA
Since the dip continues relatively unchanged off-axis and directivity is smooth through that region, one may find success EQing that out.
tuga
Oxford, England
The JBL's PIR performance is worse in every band except grey and blue (2.2-4.3kHz).
P.S.: and green
napilopez
NYC
Interesting how so far the two towers measure worse than their bookshelf counterparts.
@edechamps This is awesome - it really puts the NBD scores in perspective. I do wonder how much little squiggles in the NBD are actually audible though, especially below 1000Hz where the room has increasing influence. It's the type of thing that affects the score calculation but I have difficulty imagining it to have a significant audible effect.
It's worth noting how the HDI is quite smooth in the upper mids and presence region instead. The 10K dip is likely to be audible for most listeners, but whether it's significantly detrimental is something else.
Is the curve correct below 100hz? JBL's own specs indicate a -6dB cutoff of 38Hz, which generally comports with the ~42Hz knee in your frequency response chart. But there's a roughly logarithmic curve from 100Hz on down that results in 38Hz being -16dB down. That seems wildly off of JBL's usually in-the-ballpark advertised specs.
I am getting a deep null at 38 Hz which I mitigated but could not remove with software tweaks. So likely there is more energy there than I am showing. Then again, no anechoic chamber is reflection free down that low so their data has error in it as well.
Absolute
I do wonder why JBL home products are always disappointing compared to the pro line, even when using their incredible drivers. Can't they find a way to make a small M2 for a reasonable price? This should be the 4367, but the price is anything but reasonable.
I'd be interested in the preference score for the M2. @MZKM ? :D
Selah Audio
A chamber can be calibrated to correct for the low frequency response errors; however, this can be difficult for some types of driver and port / passive radiator layouts. If you had a deep null at 38 Hz that's pretty close to the port tuning. This indicates that you're probably not capturing the output of the rear ports. I do nearfield tests for bass extension and it yields better results than you're getting from the Klippel machine. Don (DB) Keele is a friend of mine and he did the research for nearfield testing which doesn't have the limitations of an anechoic chamber. The signal-to-noise ratio using Don's method is very high.
The correction is approximate. Since the behavior is modal and hence location dependent, there is no one correction that works, especially when we are dealing with current situation of ports, drivers and microphone being in different locations. Here is an actual comparison:
Blue is in-room. Red is anechoic with calibration. Black is Klippel NFS. As we see, the red line/anechoic becomes wrong below about 30 Hz.
Selah Audio
Please see my edited post concerning your 38hz issue. Here you're basically dealing with the size limitation of a chamber. The in-room curve also shows how the noise floor becomes a problem. I always get a good laugh when I see a post with a REW graph and the owner claiming his subwoofer is flat to 8hz.
617
Somerville, MA
Performance is as expected for a speaker of this format. Waveguide helps but can't meld with the big woofer array. Output should be a strong point.
I can help but notice that JBL is really lacking in the design department. The Revels aren't particularly stylish although they look like a premium product, but these? Compared to the focals and b&ws at this price point, these look quite plan and cheap.
