Hypex NCx500 Class D Amplifier Review
Rate this amplifier:
    Votes: 3 0.6%
    Votes: 6 1.3%
    Votes: 56 12.0%
    Votes: 400 86.0%
ex audiophile
Seriously, those 'preamps' are hardly anything more than obscure products. Their sales would be insignificant and their installed base, even less significant. They are not, nor ever will be mainstream HiFi preamplifiers. Probably sold 10 thousand between all of them.
Let's get real. The standard input sensitivity for domestic HiFi power amplifiers has been 1.0-2.0V for 50 years. Even with balanced, you can double that on a bad day. So 2.0-4.0V. Anything else it utterly stupid.
Yes, I have preamps that will output 30V RMS, but they are outliers and their rated output is 1.5V.
12dB is a joke. Nobody takes that seriously. Power amplifiers are ~26-29dB. Even Amir tweaks his integrated levels to be somewhere near that.
Don't be shy, tell us what you really think John! ;)
delta76
Wow Given that I am terrible at DIY, where can I buy this in EU assembled and does not cost a limb and leg?
GXAlan
Q: Is there a current Hypex-based fully-assembled & US-available unit that gives about 100 wpc for 8 ohm speakers?
Billy Budapest
Great to see these test results challenging Purifi in the high power Class-D space.
What about testing ICEedge amplifier modules? Did those ever come to market?
Eyexlr8
Load invariant - so what would happen if use this on a Apogee Scintilla 1 ohm version ?
does it go into any protect mode or actually keep on trucking ?
DanielT
Sweden - Слава Україні
Thanks Amir for the review and measurement!:)
What was the bandwidth when you measured? A bit curious about that.
Let's say 50-60 watts in 4 Ohm regarding distortion in the higher frequency registers, 10-15 kHz, (where we are most sensitive to distortion) there this NAD C 320BEE is as good, or better than Hypex NCx500?
Sokel
It includes Peachtree's buffer but it's close to specs in some areas:
And there's plenty of them on market,some even assembled.
(you can find both here)
Rick Sykora
Stow, Ohio USA
One interesting aspect of the NCx500 is how much light it gives off. The reason for this is twofold:
  1. The vertical regulator boards have sets of red LED arrays that light up as an H.
  2. A bright white LED (seen below on the middle right edge of the board).
Do these serve any function? The data sheet does not indicate. The NC1200 has comparable regulator LEDs. The white one is close to a thermal sensor, so my best guess is it may indicate thermal overload.
Purité Audio
Industry Insider
Barrowmaster
London
Does anyone make a ‘preamp’ the ADI ‘pro’ is a contemporary preamp , connect everything to it digital/analogue it is a terrific bit of kit.
GXAlan
In an PM-10 interview, Marantz talked about using LEDs as plain audio diodes because they could find more consistent/higher quality diodes by buying LEDs. There are a ton of lights in the PM-10 which serve no purpose.
Could that also be the case for the NCx500?
BR52
Germany
It is
BR52
Germany
They’re low noise stabilysators used like zeners in a cicuit see post #57
Edit: the LED's used like Zenerdiodes with better noise performance in seperate a build cicuit boards to substitue the 7812 and 7912 linear voltage regulators.
AndreaT
Commonwealth of Massachusetts
105 Centigrade Caps!
USER
Hypex amps are consistently superb! Can't wait until you test one of these:
I see they are now really pushing to cut out the middleman. :oops:
To think that someone considering something like this would not also consider a Benchmark or RME for max performance is a bit naïve. Slowly but surely, the times are a changin'.
GXAlan
Agree. In real world conditions, I have found a >20 year old Sony TA-9000ES to beat Hypex NC252MP handily when matching real world output due to the higher gain of the TA9000ES.
It makes it hard to really compare 5W SINAD.
Would make more sense to compare a fixed output voltage from the APx555 IMHO.
It’s OK to have multiple tests, but for AVRs as preamp, which represent a big part of the market, we really need 29 dB unbalanced gain testing too.
Vacceo
There is no free lunch. Somewhere the gain to drive the speakers has to come from. You need to look at the SINAD over output voltage performance of both preamp and power amp to determine the “sweetspot” (best overall SINAD) - Amir provides those graphs.
But yes often this is with high preamp output voltage and minimum power amp gain. Eg with the RME and the AHB2 you can set the gain of each device to the best combination. (But let’s keep in mind we are talking transparency either way). If however you take one of the Denon AVRs in preamp mode, they exhibit an increase in SINAD past a certain output voltage, so here you would set the AHB2 to a higher gain to keep the Denon in it’s best performance range.
Is there an inherent advantage at matching both gains or it does not matter?
Toni Mas
I also see Hypex has this coming
If the assembled unit is at same price range as LA90 (800-1000$) I would find it extremely strange for anyone to buy LA90.
Not me. LA90 is stereo, though bidgeable. These Ncores mono. Nothing comparable.
But i would not buy LA90 though, too expensive and need more than 2 channels.
HarmonicTHD
Beyond certain (inaudible) SINAD level it practically does not matter.
Being who I am, I personally would optimize it for my peace of mind :)
(I mean the RME and the AHB2 provide you all the tools so why not do it. And I would expect this amp will also come in different configurable gain settings. Let’s see what Amir says about the buffer board ).
