I just watched another video by Cameron where they are talking about headphones and how they do NOT do soundstage anywhere near what speakers do. Im thinking room reflections are what his headphones are missing.
Direct sound only, composite sound, which? Measuring is how to do this. Even a wall at 'n' feet isn't necessarily "that far away" if it resonates, because that effectively changes its distance.What kind of phase disparity is involved in those delays across the hearing spectrum with a room of such dimensions? Maybe a proper acoustician would know? Can this be calculated manually with resolve or is this super computer stuff?
...and a severe phase relationship. It must be horrible with some rooms.I just watched another video by Cameron where they are talking about headphones and how they do NOT do soundstage anywhere near what speakers do. Im thinking room reflections are what his headphones are missing.
I suppose you are bang on that there are so many instantaneous values that it is math heavy? To change the instantaneous distance value would require severe deformation of a reflective or absorptive surface. A reactive surface.Direct sound only, composite sound, which? Measuring is how to do this. Even a wall at 'n' feet isn't necessarily "that far away" if it resonates, because that effectively changes its distance.
I'm thinking a half wavelength is the severest situation respective of it's duration and whether leading or lagging the reference/standard? Do you work with inches or millimeters or both?No, it doesn't have to move very far, all it has to do is shift the phase of the reflection, and it can be up to half wavelength in effect.
Doesn't matter. The wall doesn't move that far, if it's resonant, it stores energy and returns it later. Necessarily.I'm thinking a half wavelength is the severest situation respective of it's duration and whether leading or lagging the reference/standard? Do you work with inches or millimeters or both?
How do you equate this resonance and the reflective materials' delay of resonance stuff with PEQing a room, standing waves and stuff like that? I mean to say it must get pretty interesting from one's mind's eye at times. How deep is the rabbit hole?Doesn't matter. The wall doesn't move that far, if it's resonant, it stores energy and returns it later. Necessarily.
I prefer to measure.How do you equate this resonance and the reflective materials' delay of resonance stuff with PEQing a room, standing waves and stuff like that? I mean to say it must get pretty interesting from one's mind's eye at times. How deep is the rabbit hole?
You have the gear to make such measurements? Like a Klippel & and other test and measurement gear? How deep does that reach? I'm not really up to speed on what your specialization or general specialty is. I saw you commenting about digital theory and it's intricacies. I'm not that deep into digital theory like you but I dig it. It's interesting.I prefer to measure.
Its seems to be cleared up now indeed..About the 'dismal mean' thing? Just this from experience: audio forums are, on average, full of cranks and what my friends across the water call 'arseholes'.
The rest of it seems pretty clear to me.
I had a listen to a system last night that reminded me of this thread. The room was 4m x 5m (13ft x 16ft), with two floorstanders and had extensive room treatment. I was told that before the treatment went in, the RT60 averaged around 700ms. After treatment, it is now about 250ms > 150Hz. Speakers were Sonus Faber Amati Tradition, $40k per pair.
Firstly, the soundstage was really narrow, confined between the two speakers which were not placed very far apart. I think that killing the first reflection point was responsible for this. However, the phantom image was really precise.
This was the first time I have listened to an over-treated room where I knew what the RT60 was. With other systems in over-treated rooms, those owners did not take measurements so I did not know. I think that 250ms is way too dry for me. It was good for having a conversation without music playing, but it wasn't great for music.
Bruckner 9? Wow, i m really impressed. I usually listen to it before Mahler's 9 and 10While it may be an interesting technical project, inviting a symphony orchestra into your home is a creative aesthetic project too. Going to Symphony Hall is the the real thing and trying to reproduce that experience at home is artifice. Successfully optimizing the recording/playback chain to transparency doesn't eliminate the artifice because playback in your room doesn't sound the same as Symphony Hall. Successfully optimizing the sound-fields in your listening space to match some Symphony Hall so you can move and hear the same thing (if that can be done, idk) just begs questions: which Symphony Hall and which recording are you going to simulate at home. And don't touch the volume control because only one setting is realistic.
My point is that whatever we do with playing recordings at home is deliberate artifice for our pleasure. We are all subjectivists at the end of the day. There's nothing better than listening to Bruckner 9 on a Bluetooth speaker in the bathroom when that's what you need.
All music recordings are artifice, no matter what your dad may have thought about fidelity ( ͡~ ͜ʖ ͡°)Bruckner 9? Wow, i m really impressed. I usually listen to it before Mahler's 9 and 10
Surely, listening at home is not the real think and depends on physical room correction as well as software. This is why my listening is sometimes happening directly from a cd player, but other times from computers where i have tons of room correction inside my DAWs. I rip the cd to whichever computer disk. I take the file into a DAW and i do room environment in the DAW, then listen. HOWEVER: no matter how good correction may be, it's finally to the speakers to render mid highs and highs smoothly. When i m writing about this on any thread, i am referring to the often harsh and brittle digital sound of violin groups, trumpets, oboes, unclear crash or riding cymbals, etc, for ex a sweeping long melodic line, such as In most of Bruckner's second movements, Brahms' First, first movement's very beginning, Fourth second movement (the E major line, first violins) or Tchaikovsky's Swan Lake, or Shoenberg's Peleas, etc, the number of such lines is innumerable. So, with me it's not even getting to the real thing, but firstly and foremostly the quality of high frequencies. This is why, when i was 16, my first move was to expressly modify the expensive tape recorder my father bought on the occasion of my performing a Beethoven Sonata in front of quite a large audience. He was, of course, quite unhappy about my delving into electronics when i knew nothing about it. Faithfully yours, P.
To conclude a long and winding side-thread about envelopment: The quality is important to audio professionals beyond doubt, but recorded envelopment often does not make it to a recreational listener, due to, for instance...
- reproduction room, unstandardised speaker setup or listener placement,
- loudspeakers with too bumpy in-situ LF, and/or response not extended to at least 50 Hz,
- pods or soundbars incapable of inducing LF channel differences in the listening space,
- lossy datareduction distorting channel differences,
- electrical summation of low octaves (mono sub, incl. distributed subs)
Whether or not the experience of auditory envelopment to a human is just enjoyable, or it also may trigger a striatal response in listeners, is conjecture for the time b
Sure, but then you probably haven't heard music recordings done on two track willy studer pro, broadcast grade recordings and reproduced on the same equipment in a radio studio. It was in 1967 and quality breathtaking.All music recordings are artifice, no matter what your dad may have thought about fidelity ( ͡~ ͜ʖ ͡°)
I did not have that actual experience back then, it's true. Audio recording and playback can of course be very impressive. And good artifice can be breathtaking. My point is that there is something distinctly artificial about putting a full orchestra into a home living room regardless of the qualities of the equipment. It's a bit like putting an elephant, or a large fireworks display, or an infantry battalion in a living room.Sure, but then you probably haven't heard music recordings done on two track willy studer pro, broadcast grade recordings and reproduced on the same equipment in a radio studio. It was in 1967 and quality breathtaking.
