It’s just the regular X-Desk. The XL is too huge for me. SiX seems nice though, compact. For mine, I’m burdened with a crap ton of DB25 cables.I love your XL. I have a SiX, not the same thing at all, I know. I'm sure it all sounds just fabulous. Cheers!
Look forward to hearing your report. ThanksLong time lurker, but finally decided to make a profile and join in the discussion on this great forum!
So I currently have Genelec 8351A + 7360A Sub (GLM calibrated) - they sound as good as they can in my semi-treated studio space.
My second set is Amphion Two18 which measure very decent considering there is no DSP or correction. (I have tested with Sonarworks and Dirac, but really don't like the smearing and loss of definition/transients so deleted them and prefer to just learn the raw sound of the monitors in the room.)
I've provided some REW charts below, but empirical evidence can sometimes be pointless...
Do they sound good? I suppose they do, but what is more important to me is that much banded word in engineering: 'translation'.
Essentially, I like having different 'sonic lenses' to hear through, which is why I also have Auratone 5c, Yamaha NS-10M, Fostex 6301 at my disposal, as well as a smattering of headphones from high end Focals to cheap £7 Panasonic buds, all to check mixes on.
While I don't really need an upgrade at the moment, there's always room for improvement (or perhaps improvement of the room?!). In any case, I am considering moving to 8361A or 8351B with W371 which is what led me here.
I am also currently demoing Dutch & Dutch 8c so will report back with my findings soon.
Genelec 8351A + 7360 (GLM Calibrated)
Amphion Two18 (No correction)
Which dealer? Been looking around for pair of 61's myselfMy two cents: I went with 61 over 51 simply because I got such a good deal from a pro dealer for the 61 that the 51 made no sense. Been looking at the 2nd hand market for over a year and they hold their resale value very well. The only downside with the 61 is that it might be physically too big =P. Haven't received them yet, still in factory painting queue.
how much did you pay? thanksMy two cents: I went with 61 over 51 simply because I got such a good deal from a pro dealer for the 61 that the 51 made no sense. Been looking at the 2nd hand market for over a year and they hold their resale value very well. The only downside with the 61 is that it might be physically too big =P. Haven't received them yet, still in factory painting queue.
One man business here in Finland. He had one pair earmarked for him at the factory so no more great deals from him.how much did you pay? thanks
audiosciencereview.com
Just wondering if you still dell the same. i'm looking at some 8260's. They are getting a bit long in the tooth though and i can get some 8351B's at a reasonable price.Owning the 8260, if I had to do it all over again... I'd go for the 8351B if I could afford it, simply because if I could afford that now, then I could likely afford a pair of W371 speakers in the future.
If the price matters to you though, and you can't afford a subwoofer with GLM, get the 8260 used for $5k and enjoy the extended bass. The S360 is also a very flat, "Genelec" sound to my ears listening at a show, but vertical dispersion and bass extension are going to be lacking.
Should have a Swarm/DEBRA subwoofer array (4 subs in parallel) soon, and for $8000 total, it should compete with just about anything if the goal is even frequency response across a wide area with excellent control of peaks and nulls.
If you're considering pairing other subs with these Genelec models for deeper bass, make sure you have a way to integrate them perfectly without GLM. I tried many positions for two PSA subs all along the front wall, and even using a MiniDSP and REW was not able to integrate them well enough for them to sound like a single unit. Might have been able to fix things with a third sub or additional tinkering, but the difference between subwoofers and Genelecs was quite apparent.
I would love to but can’t turn it horizontally to fit under the TV. I thought about the 6C but it would be a really tight fit as well. It may work if I could figure out a way to angle it.Why don’t you get a single HC for the centre channel?
To revive your revival: I have a system that now includes the 8361As and both engaged this thread and held various discussions in settling on that conclusion. I attach a recent key conversation around choice of monitor that I held with ChatGP and Gemini and the affirmative conclusions therein. On the basis of all my research, auditioning and various conversations, I have ended up deciding on the following 'end game' setup:I thought this would be the best place to revive this discussion after reading through the posts. I am going to get a Genelec 8351b or 8361a for my center channel to go with my Dutch & Dutch 8Cs as L/R. I will be using four subs with Trinnov Waveforming. Is my understanding correct that I am only giving up a bit of SPL? My listening distance is 10 feet. The 8Cs are plenty loud in the listening position for my tastes. It looks like on paper the 8351b is as loud as the 8c.
- Genelec 8361A (x2)
- Genelec W371A (x2)
