Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
back in the days I used to bring my old KRK ROKIT8 G1 to 31Hz-ish (in room) with this method. never had any problems, and after all those years I still use the speakers for outdoor parties (not EQed)
Also we shouldn't forget the spectrum of most music which is decreasing above 1 KHz, treble above 100 dB sounds extremely loud and neither nice nor healthy.
GLM can implement what OP wants to do. Genelec won't allow a low shelf with positive values, so use negative -9dB shelf and add +9dB of system gain.
Let's see how Genelec's speaker plus limiters respond to the EQ. Here is the -9dB shelf, with +9dB of system volume. I smoothed since I was unwilling to move the speaker away from the wall.
We don't get any improvement in 'extension', we get a boost at 30Hz, with the shelf EQ truncated below that: exactly 4.5dB of boost below at 30Hz, no additional boost below despite the shelf. I could likely overcome even this with aggressive external DSP, like some freeware VST plugin. But even with Genelec's DSP brick-walling my shelf below 30Hz, I can see the woofer The woofer visibly moves more with the EQ plus gain, quite dramatically. If I want to change the 20Hz response, moving a few cm is going to be larger than what I just did with GLM.
