This change to Genelecs has required I learn new DSP room correction and bass management software.
I'm going from MiniDSP/DiracLive to Genelec GLM and there are definitely pro's and con's to each. I'll just focus on GLM.
Pros
- I think the biggest pro is the GRADE report, which covers key areas like early and late reflections, with suggestions on how to fix.
- The second biggest pro is the room correction algorithm, which I think is a hair better than DiracLive.
- The third pro is the phase correction which is miles better than anything I've used. It's really good.
Cons
- The biggest headache is the lack of control. It doesn't have the bass management tools I am used to with MiniDsp. Come on Genelec, I should be easily able to roll off my subs at 15hz or whatever. I confirmed with support that implementing a roll off is an incredible pain in the ass to do with GLM. Weak.
- It's slow, especially the phase correction. I found it more tedious to go back and forth between REW and GLM to do trial and error testing.
- GLM has some quirks with volume control that are unforgivable. It will go to full or nearly full volume seemingly randomly when you go in and out of GLM calibration modules. It has caused some unexpectedly loud sound.
- The GLM metal volume control for an extra $100 is gorgeous but it stops working after an hour or so unless GLM remains connected to a pc.
- The software is klunky. MiniDSP isn't going to win any design awards but the actual use of the tool is easier. GLM has way too many dialog boxes.
GLM gets the important things right and is my overall favorite. But it's lousy UX and software bugs take away from the experience. They are so avoidable.
