staticV3
- Joined
- Aug 29, 2019
- Messages
- 15,161
- Likes
- 26,700
KRK has three subs with a crossover which you can switch between four frequencies, namely the S8.4, S10.4, and S12.4Budget is around 500€ but I am willing to buy used
I'm located in Germany
I don't really have a need to go really deep
No size constraints
I would like a satellite filter so I can easily avoid sending the 8010s low frequencies
Compared to your ESI with its fixed 100Hz crossover frequency, that flexibility may allow you to achieve a better subwoofer integration.
Though it should be noted that the available crossover frequencies are different for each model.
The S12.4 for example has its highest crossover frequency at 80Hz, which may already be too low to work well with the 8010a.
The S10.4 and S8.4 can go up to 90 and 100Hz, respectively.
As always, a measurement microphone and room correction is highly recommended.
