If you do want to get ahead with this, please note that you'll want to make some RaneNote 110 #17 cables.
I was thinking about buying something like this one:
My Gen 3 works perfectly under linux. I'm wondering what they're adding? It's just a class compliant USB2 device, no?In something of an about-face, Focusrite are now helping a 3rd party developer add linux drivers for the 4th Gen Scarlett. This should remove the need for reverse engineering and guesswork that has gone into the previous drivers, and help both in quality and development time.
https://linuxmusicians.com/viewtopic.php?p=160833#p160833
People are using these with active speakers all the time, so as long as you have balanced inputs, sure.but could it work as a preamp into a power amp
No. Some higher-grade audio interfaces can be computer-controlled entirely, but something in this class will be operated manually. If you need a remote, what you want may be a consumer-grade DAC instead., and if so does it have a remote control handset?
Maybe Julian Krause on youtube.Any measurements published anywhere yet on the 2i2 4th gen?
