AnalogSteph
I hadn't noticed that the headphone outputs are actually different between the 4th gen 2i2 and 4i4... huh. That's one way to upsell you on the more expensive model, I guess.
The Audient has a bit over twice the power of the Focusrite 4i4. Of course that is only 3 db louder. The Focusrite has lower output impedance, but with the phones you have not an issue.I want only power my speakers and headphones (hd600 and dt1990), so:
Focusrite 4gen or audient id4 mk2?
Just for headphones, no, though the Mbox specs are a tiny bit more power. Not sure why you would switch if the Mbox is doing what you need.Previously I've got Mbox Studio, is this will be noticeable downgrade?
MBOX Studio – Audio Interface for PC and Mac – Avid
Capture vocal and instrument performances in pristine sound quality with a premium audio interface for PC and Mac. View MBOX Studio hardware specswww.avid.com
3 db lower output from 4i4. Not a big difference. Whether it matters depends upon the speakers. Probably not an issue.And what about speaker output? Can this be the same quality?
As always mbox is almost 900$ and Audient id4 mk2 is 200$
That's comparing apples and oranges, mind you. In terms of available I/O, the Mbox Studio is much more comparable to a Clarett+ 4Pre ($700 retail, now $600, and IMHO a better performer though obviously the ergonomics are totally different). It has 4 Mic/Line/Inst inputs plus 4 line-ins, two sets of monitor outputs and two independent headphone outputs, FX send/return, plus SPDIF I/O and ADAT input.As always mbox is almost 900$ and Audient id4 mk2 is 200$
Wonderful! Thank you so much! Amazing!!!Unless your headphones are very impedance-critical, I'd say the iD4 MkII should work fine for you. It's a good bit above average in the headphone department, particularly at mid-high impedances. (I just hope your two cans aren't wildly different in sensitivity.) A level of +12 dBu on the monitor out should still be plenty high enough, too, and output noise should be so low that you'll only be hearing what the monitors themselves generate.
If one of your headphones happens to be a model that you can inexpensively get a good balanced cable for, something like this would be another option, also $200-ish:
DL200
Foshan ShuangMuSanLin electronics Co., LTD. founded in 2009 which located in Shenzhen, China. And our branch company VMV Technology(HK) Company Limited registered in HK in 2013. Our company is specialized in the audio DAC, stereo headphone amplifier, power amplifier, and with own R&D...www.smsl-audio.com
