3dB higher SNR, likely because although they use the same ADC chip, on the E1 they can do channel summing.
Hmmm, interesting.3dB higher SNR, likely because although they use the same ADC chip, on the E1 they can do channel summing.
Meaning that the Stereo ADC inside digitizes the input signal twice, then the two channels are combined internally and the noise averages out.
I assume they indeed used the picture from the 4x4. The 4x4 has two headphone outputs, and these are likely the headphone amp modules. The 2x2 has one, the 4x4 has two...What is that component that the 2x2 OTG has two of and the 1x2 OTG just one?
Edit: on the Julian Kraus's review of the original 2x2, there's only one component. Maybe they've used the wrong picture (from the 4x4).
I own the OG 2x2.hearing a lot of mixed things about this. i really care about headphone output and i want an all in one system and Julians led me to believe that this is a really good fit for me. but im hearing there is quite a bit of issues with the system? does the otg only provide connection to mobile devices and no other difference? thanks
Which issues have you heard of?hearing a lot of mixed things about this. i really care about headphone output and i want an all in one system and Julians led me to believe that this is a really good fit for me. but im hearing there is quite a bit of issues with the system? does the otg only provide connection to mobile devices and no other difference? thanks
The E2x2 behaves like any other modern DAC: It outputs whatever you input, without adding anything to the signal.I don't produce music and I would like to use it for listening to music. How do you think he behaves?
From what I can tell, the FiiO JT1 is a headphone, not a headset.I currently have a FIIO JT1 headset that I'm using with a Sound Blaster Z SE but I'm not happy with this sound card. Do you think I made the right purchase?
www.audiosciencereview.com
I believe it's analog on the device itself but obviously digital in the software mixer. The meters on the front are responding to realtime analog signal as well supposedly.volume adjustment is digital or analog sorry? I can't understand from info ...
Main out volume control knob (as well as the Headphone volume of course) and the level meters are indeed analog.I believe it's analog on the device itself but obviously digital in the software mixer. The meters on the front are responding to realtime analog signal as well supposedly.
I'm beginning to question whether these input gains aren't digital after all. I have plenty of evidence for the main line out and headphone volumes in their documentation, but haven't seen any for the input knobs, I just kind of assumed. Do we have evidence for these being analog?Main out volume control knob (as well as the Headphone volume of course) and the level meters are indeed analog.
Input gain: also analog. There is 20dB extra 'digital' gain available on the inputs in the control panel, but that should (according to Topping) only be used if the gain on the device is maxed out and you still need more (gain AND noise![]()
Having played with it a lot yesterday, the input gain definitely seems analog.I'm beginning to question whether these input gains aren't digital after all. I have plenty of evidence for the main line out and headphone volumes in their documentation, but haven't seen any for the input knobs, I just kind of assumed. Do we have evidence for these being analog?
The reason I got down this line of thinking is I was watching the Julian Krause review of it again yesterday and he shows in a graph that the input gain knob at 100% begins losing linearity roughly over 8k, but then shows it having nearly perfect linearity when the knob is around 75%. As we know there is a weird volume gain boost at around 80% which makes me wonder if it is activating some digital boost pad at that point.
I understand your comment is saying the software offers a digital boost above the highest gain of the knob, but I'm beginning to wonder if that digital boost is enabled by default and that maybe installing the software will allow me to disable it?
As I've mentioned, E1x2 seems to have seems to have a slightly better input DNR. And as staticV3 explained:Hey Amirm, do I need to the OTG version to play back audio from a phone or will the your tested non-version work?
Also, does the E1x2 perform equally to the E2x2?
Having opened up the unit and examined it, and as far as my limited understanding of PCB circuitry goes, I can tell you this: the input gain knobs are analog pots. And pots control a VCA-circuit, integrated in or combined with the ADC-chip, which then translates the setting into a gain value.I'm beginning to question whether these input gains aren't digital after all. I have plenty of evidence for the main line out and headphone volumes in their documentation, but haven't seen any for the input knobs, I just kind of assumed. Do we have evidence for these being analog?
