Just curious whether I have to get the OTG version to connect my phone and play back from it?As I've mentioned, E1x2 seems to have seems to have a slightly better input DNR. And as staticV3 explained:
I enable the outputs I want to use with my phone (line, HP or both) on the control center app and download the settings to device first (if you don't only the outputs selected in your last session will work). Then I disconnect the interface (power and usb-c) and only plug in my 5 year old Samsung (android version Ancient.2). It powers the interface, with signal to the output(s)s you selected. One thing: on my phone a rather large white mouse-pointer appears spot in the middle of the screen. I just ignore it and it does not move or interfere with phone operation. Mono signals are sent to left out only. When it works, it works, but when connecting my phone freezes like half the times. No big deal, just disconnect the phone. Then try again (a few tries tops). There might be a procedure where a certain sequence of device and phone powering up or down and connecting will always just work, but I haven't found it. Stopped looking for it, when I began to seriously doubt the actual existence of this mythical sequence. Both devices only agree to aknowledge they know what it is you want and grant you that wish after randomly plugging/unplugging and powering things up and down a few times. Takes ten seconds.Just curious whether I have to get the OTG version to connect my phone and play back from it?
www.audiosciencereview.com
Thank you for that analysis. I'm wondering if some mods will crop up over time.Having opened up the unit and examined it, and as far as my limited understanding of PCB circuitry goes, I can tell you this: the input gain knobs are analog pots. And pots control a VCA-circuit, integrated in or combined with the ADC-chip, which then translates the setting into a gain value.
However the input gain pots are of a dual layer layout. In short: instead of being a 'simple' variable resistor (like the main out, headphone out and monitor/input mix pots are) they are in a way two pots in one. They give two resistance values for every position. What those values are, their correlation, and most importantly what the ADC Chip is programmed to do with the combination of those values is anybody's guess but Topping's. It might well be the explanation for the non-linear behaviour of the inputs at and above certain gain levels mentioned before.
In this repect there is certainly room, and even a need, for improvement in future implemetations of Topping intefaces of this type.
The E2x2 can drive low impedance headphones.Hi everyone,
I like to get low impedance Headphones (16-20 Ohm) and my current Interface can't drive them. Would it be a problem for the E2x2?
Are you sure?Hm, actually appears to be cheaper to order from France. In any case it's over $200 though. Wonder why Topping doesn't have any U.S. distributors.
It is often cheaper (in EU) to buy Topping products from Audiophonics than from Aliexpress. Just bought a regular e2x2 from them for under 170€, shipping included.Hm, actually appears to be cheaper to order from France. In any case it's over $200 though. Wonder why Topping doesn't have any U.S. distributors.
Amazon has them in stock sold by Toppingaudio now.Is AliExpress the only way to order one of these in the U.S.?
Interesting question. My guess (and anybody's until someone tries it) is that it will work. But likely with some, unpredictable, loss in functionality. Buy it, try it, send back if it doesn't work...Looking to buy a e2x2 otg. Instead of connect to PC and mobile, would it work with dual PCs?
5 V @ 0.8 A doesn't exactly suggest a power miser, and I wouldn't count on more than 500 mA from a mobile device. Even if it does work, I'd really want to have a USB powerbank to avoid draining the iPad's battery roughly twice as fast as normal. Ones with around 20000 mAh seem affordable enough and should give you roughly 16 hours or more of operation.Can this be powered from an iPad like my Arturia can
Thanks for the reply. It does look as if it needs assistance so it’s one to think about.5 V @ 0.8 A doesn't exactly suggest a power miser, and I wouldn't count on more than 500 mA from a mobile device. Even if it does work, I'd really want to have a USB powerbank to avoid draining the iPad's battery roughly twice as fast as normal. Ones with around 20000 mAh seem affordable enough and should give you roughly 16 hours or more of operation.
