Each? For a pair.That said, this is a passive speaker that costs $3500-$4000 each.
Pair.Each? For a pair.
woodwork to die for.
8.8 is a new record for Klippel NFS measured speakers right?Let me break some good news: score is 6.9 which is stellar for a passive speaker.
Code:SPK auEQ ----------------- NBD ON 0.29 0.24 NBD LW 0.25 0.20 NBD PIR 0.21 0.16 SM PIR 0.91 0.96 SM SP 0.99 0.99 LFX 34 32 LFQ 0.84 0.84 ----------------- Score 6.9 7.3 w/sub 8.5 8.8 ----------------- +6.88 +7.32 March Audio Sointuva
An EQ doesn't help much so I also boosted the bass a bit and get the score up to 7.3.
As always you can play with the EQ to taste, i would remove the small ones and keep only 2 and even like that it would be worth listening to see if that improves the sound or not.
The speaker is really ugly but it should perform.
March did a great job.
Here is the EQ in details:
Code:EQ for March Audio Sointuva computed from ErinsAudioCorner data Preference Score 6.9 with EQ 7.3 Generated from http://github.com/pierreaubert/spinorama/generate_peqs.py v0.14 Dated: 2022-01-07-08:39:44 Preamp: -1.9 dB Filter 1: ON PK Fc 156 Hz Gain -0.84 dB Q 3.87 Filter 2: ON PK Fc 2086 Hz Gain +0.94 dB Q 2.41 Filter 3: ON PK Fc 1296 Hz Gain +0.77 dB Q 5.97 Filter 4: ON PK Fc 208 Hz Gain -0.51 dB Q 5.29 Filter 5: ON PK Fc 127 Hz Gain -0.50 dB Q 5.85 Filter 6: ON PK Fc 41 Hz Gain +2.96 dB Q 1.35 Filter 7: ON PK Fc 105 Hz Gain -0.51 dB Q 5.89 Filter 8: ON PK Fc 265 Hz Gain -0.52 dB Q 6.00 Filter 9: ON PK Fc 1702 Hz Gain -0.56 dB Q 5.84
Each? For a pair.
What makes you believe that "playing louder and cleaner" for a specific size is how you define state of the art? I personally think those things are considerably less important than low frequency CD or perfect directivity in all dimensions.Some ASR members really don’t know how to read measurements without Armir’s commentary. Or they’re not paying attention and don’t really know what else is out there.
This 1/2 cu foot speaker IS state of the art.
It plays louder and cleaner and is smaller than others 1/2 cu foot speaker.
Nope, the ASR measured Genelec 8030C has 9.0.8.8 is a new record for Klippel NFS measured speakers right?
I mean you're free to prioritize what you want, but it's pretty childish to say people don't know how to read measurements when we know for a fact that distortion measurements are a useless disaster that often don't correlate to anything audible.
You're a laugh riot. People offensively stating objectively wrong things go straight to my ignore list, and 100% permanently. One of the worst posts I've seen on this site. No correlation of directivity with preference. ROFL. Read Toole's book instead of posting slides you misunderstood. Directivity is literally the core of what makes a speaker good or bad.There’s no known correlation of directivity with preference.
He's right though, the model does not favor narrow directivity speakers over wide directivity speakers or vice versa. it only punishes directivity mismatches.You're a laugh riot. People offensively stating objectively wrong things go straight to my ignore list, and 100% permanently. One of the worst posts I've seen on this site. No correlation of directivity with preference. ROFL. Read Toole's book instead of posting slides you misunderstood. Directivity is literally the core of what makes a speaker good or bad.
Initial pricing for a pair will be $3495 USD for painted finish (any colour you like) and $3995 for wood finish. This is significantly cheaper than the $5000 some were predicting earlier in the thread
I am a little suprised by all the praising because of the HF rise. I have seen other speakers beeing lynched here for less lol
