It only counts if you can hear it in the speaker. Knocking on sculptures and musical instruments is useless. Everyone know what knocking on a stone and an intentionally resonant cavity will do. That’s a good example of dumb marketing talk.
Solid cabinets have higher resonances, but when they are triggered they ring persistently. There is another school of thought (espoused by those following in your own speaker’s designer’s footsteps) that speaker resonance should be damped at lower frequency to inaudible levels.
Either way, it shows up in measurements and does or doesn’t reach an audible level ( and even then may be masked). I’ve found three sets of Wilsons fatiguing. Probably just due to uneven HF response or dispersion.
Sidebar 3: Measurements I used DRA Labs' MLSSA system and a calibrated DPA 4006 microphone to measure the Wilson Alexia's frequency response in the farfield, and an Earthworks QTC-40 for the nearfield and spatially averaged room responses. Because of the speaker's bulk, I was unable to raise it...
www.stereophile.com
Sidebar 3: Measurements I used DRA Labs' MLSSA system and a calibrated DPA 4006 microphone to measure the Wilson Sabrina's frequency response in the farfield; for the nearfield frequency responses, I used an Earthworks QTC-40, which has a ¼" capsule and thus presents no significant obstacle to...
www.stereophile.com
