agnostic1er
- Joined
- Feb 22, 2025
- Messages
- 28
- Likes
- 56
Hello,
Tiny passive 2-way speaker, intended for nearfield listening (up to approx. 7 feet)
1 Woofer: SB acoustics SB12PFCR25-8
1 Tweeter Monacor HT22/8
2 passive radiators Peerless SDS P830878
I named it “aGnome”, a mix of my nickname and “gnome” (french for “dwarf”).
My goal was to create the most affordable standed/bookshelf speaker with an enclosure of H10.12” x W5.75” x D7.24”, so a size smaller than the well known LS3/5A.
With 0.59” panel’s thickness (mdf), Vb is 3.7 liters, so a bit less than 1gal us. In such a tiny volume a vented box isn’t wise. With most of presently available small drivers, we don’t get enough bass from closed box. So I decided to go passive radiators.
Building is very easy, no need of flush mounting the selected drivers.
The real challenge was to create an x-over with as few components as possible for a question of price but also because of the available inside space.
Beside its low price, I selected this tweeter because, being a cone tweeter, it helps align its acoustic center with that of the woofer and smoothes directivity mismatch, a bit like a waveguide. And indeed it works in such a way.
Usually I use VituixCAD with each driver off-axis measurements to create the x-over of my speakers. Not on this one because at the time I didn’t work this way. However, I measured the horizontal (0-90°) and (0/90 and 0/-90°) vertical off-axis with ARTA and got a power response that was satisfactory to my ears. Eq-ing the remaining anomalies did not improve the listening result.
Only 4 components make up the filter.
Listening results: Good tone balance despite light bass and treble missing sparkles. Lack sub-bass. Not very detailed, rather sweet sounding but with natural timbers i.e. beautifull male and female voices. Enough dynamics at safe listening levels in small rooms / nearfield listening. Very good soundscape, width and depth. Matched to a subwoofer, even with a 50Hz low-pass, its global qualities could compete with some floorstanding speakers.
