Amir needs to retest version 3 of this amp. Maybe there is even a v4 at the time I am writing this.
I bought mine 2 weeks ago and received a V2, dated 2025/01/08.
Why did you replace the Loxjie? Is the A5 that much of an improvement over the A30?Based on the review I just got one of these to drive a secondary bookshelf system that I put together as a DIY project. Running mostly Roon and Qobuz as my musical source through a Raspberry Pi 4 with a Hifiberry DAC2 Pro HAT. I can't believe how compact a system this is. It is replacing a Loxjie A30 mini-amp/dac.
I launched and installed the new Discrete Style opamp AK05 on Akliam and it looks great with the A5.
According to A5 specs, the device's input voltage is DC 24-48V. As for the OP-AMP working voltage.... it should be lower. More powerful powerbrick means more output power on the speakers.I was thinking of doing it myself. Are you using it with the 48V 5A power brick?
The seller says the operational voltage is ±9V ~ ±22V so I thought 48V would be pretty out of spec... or it doesn't really matter?
Not that I can discern subjectively with my six decade old ears, but I do like the tiny form factor, simple, minimalist design with a satisfactory "click" to the dial to power on and off. And the low cost made this a super easy impulse buy. I may also give this to my daughter who lives in a very space constrained apartment. Such great sound coming out of such small boxes is pretty amazing!Why did you replace the Loxjie? Is the A5 that much of an improvement over the A30?
Any thoughts on the A5 Pro vs this one? I feel like the variable high pass filter is a really important feature. Or do the tone controls somehow overlap with the filter functionality?
For someone who wants perfect sub integration, probably no. But obviously this is not the type of equipment high rollers look into.I feel like the variable high pass filter is a really important feature.
For me it's the latter and, perhaps more importantly, the ability to place a subwoofer in a position that distributes bass frequencies around the room better while not compromising the stereo imaging of the mains.For someone who wants perfect sub integration, probably no. But obviously this is not the type of equipment high rollers look into.
- For someone who has a pair of low to upper medium class bookshelf/tower speakers that reach deep but lack quality (typical boomy sound) -> Go for it! It will clear them up, free the speakers from resonance they can't handle well and you can plug a sub to it. You will get even more sonic improvement out of this than you would get out of vastly better amp in terms of SINAD.
- For someone who has a pair of upper medium to high end bookshelf/tower speakers and does not enjoy or cannot play deep base -> Go for it! "same logic"
How would an alternative power supply improve the sound? Has this been measured?In any case. You shouldn't use the official power suppy unit. Buy a decent one from Meanwell, get the GST360A 48V/360W/450W peak or the 36V of the same model. They have remarkable low noise/ripple. In the range of a small 5V adaptor.
The speakers have an impled subwoofer crossover freq of ~175 Hz based on the subwoofer that was designed for them. I'm not planning on playing them loud, they are for a small desktop setup, so I don't think another PSU would be necessary.For someone who wants perfect sub integration, probably no. But obviously this is not the type of equipment high rollers look into.
| Clock position | Frequency (Hz) | Step (n) |
| 7 | 30 | 0 |
| 8 | 47 | 1 |
| 9 | 64 | 2 |
| 10 | 81 | 3 |
| 11 | 98 | 4 |
| 12 | 115 | 5 |
| 1 | 132 | 6 |
| 2 | 149 | 7 |
| 3 | 166 | 8 |
| 4 | 183 | 9 |
| 5 | 200 | 10 |
| Clock Position | Frequency (Hz) | Step (n) |
| 7 | 30.00 | 0 |
| 8 | 36.27 | 1 |
| 9 | 43.84 | 2 |
| 10 | 53.00 | 3 |
| 11 | 64.07 | 4 |
| 12 | 77.46 | 5 |
| 1 | 93.64 | 6 |
| 2 | 113.20 | 7 |
| 3 | 136.85 | 8 |
| 4 | 165.44 | 9 |
| 5 | 200.00 | 10 |
Has anyone managed to take any measurements of the high-pass filter knob at various clock positions yet? It's not labelled and there are conflicting pieces of information about it.
I launched and installed the new Discrete Style opamp AK05 on Akliam and it looks great with the A5. The personality is close to Burson Opamp and I like it. It also looks great with the A5.
Where did these pictures come from? Is this a new version?
From my SmartphoneWhere did these pictures come from?
