apologies in advance, I had to do itlet me wipe my black makeup and test this
update: blasting some Sisters of Mercy (my neighbors thank you). no pop
Very unlikely with a post feedback control. The amp surveilles its own output. If you hear cracks or pops you should check your DAC first and make shure it is isolated from the mains.
I'd really like to respond with any kind of laughing smiley, but the forum software won't let me. Please, imagine me rolling on the floor, laughing.let me wipe my black makeup and test this
True, the data sheet says typ. 36 V and max. 38 V DC supply voltage. What we don't know (at least I don't) is if the output of the external PSU is really directly fed into the PVVD pins without any further regulation.TPA3251 is typically rated for 36V. There is support for 38V in the data sheets but it is considered the limit. Do you guys think this is an issue long term usage wise? Maybe one would be advised to swap the PSU for a decent 36V one. Output power decrease should be minimal. Sound quality should -if anything- improve ever so slightly.
Good idea to keep an eye on this, but I don't see a problem here. The writing on the power brick (at least on the ones that I received) is actually:On the GAN power brick is says:
input: 230V 3.5A / output: 38V 5A
yet, the power cable that ships with the amp says:
230V 2.5A max. / it is a 2x0,75mm only
Did you examine your own amp or did you study the pictures posted here, mostly showing pre-production models?There is a third ground pin from the PCB to the DC-IN roundport. But since there is no third grounding pin to the wall from the PSU, the ground from the PCB leads only to the PSU. Isn't this (aside from the unmatching cables) a safety hazard?
Everyone please be careful when you power it the first time.
The button for putting the amp into bypass mode is somehow inverted (from common logic).
If you look directly at the button and at the backside of the amp one would assume "to the right = bypass on" but it's the other way.
Thankfully I was clever enough to play the first sound with 5% vol otherwise the combination of DACmode+bypassmode would have been really nightmarish.
With my A5 it was disabled by default. However I got confused due to the bypass trigger being "on" at the left position.I remarked how they should have the volume bypass disabled by default
There is no turn off pop! Amir got a pre-production unit that probably got fixed in that regard. His unit also had 12V Trigger which they abandoned for the auto-off feature which is awesome. There is a "click" from a relay within the enclosure when it shuts itself off and two clicks when it shuts itself on (soft clicks to the ear). I like that click. It's reassuring the amp is doing what it is supposed to do. The amp is as silent as a grave to the speakers. However, I have also wrapped the AC-IN cable many times around a big donut shaped N30 Toroid to clear the PSU from high frequencies.The lack of turn off pop was final deciding factor.
As said elsewhere before ...Everyone please be careful when you power it the first time.
audiosciencereview.com
That's the point. You can read " | bypass vol" or you can read "bypass | vol".There is a switch, whitch is either in the BYPASS position (left) or in the VOL position (right).
We're in summertime but my A5 also runs a little hotter than I would prefer. You have to keep in mind that the amp board is hanging from the top down, hence the PCB is directly heating up the upper side (which is the side you would most probably touch). Actually this is a better solution than a laying PCB that most amps have since the heat wants to go up anyway.However, it runs hotter than I would like.
I set the bypass volume switch to off so that it bypasses the volume pot. Once set I never have to read anything because my needs are not so fickle. Set and forget. Who cares what it says, as long as it provides switching ability.That's the point. You can read " | bypass vol" or you can read "bypass | vol"...
Me neither. As long as the DAC does not for some weird bug go into DAC mode all over sudden, I am fine.I am never that trusting when my speakers are at risk.
"Hotter" is a very subjective term that can mean 32°C or 60°C.We're in summertime but my A5 also runs a little hotter than I would prefer. You have to keep in mind that the amp board is hanging from the top down, hence the PCB is directly heating up the upper side (which is the side you would most probably touch). Actually this is a better solution than a laying PCB that most amps have since the heat wants to go up anyway.
We could add some cooling fins to the top. If 3E Audio was cool too, they could be making sure we get some perfectly matching fins with some preinstalled thermal pad to glue it right onto the top. I'd pay up to 20 Euros.
For sure this is the case. Anyway there are two things I don't like electronics running on for years to come. a) at the peak of their allowed voltage b) at temperaturIf you can leave your hand on the amplifier for 10 seconds without burning or hurting yourself, there's nothing to worry about.
You're overlooking a few points.For sure this is the case. Anyway there are two things I don't like electronics running on for years to come. a) at the peak of their allowed voltage b) at temperatur
Both can be mitigated, the latter even with considerably low cost. I don't want an amplifier to die ever. Not in two years, not in twenty.
I just received my e3 audio A5 amplifier. I intended to use it to upgrade the amplifier bit of my sr5011. Unfortunately I do not hear any audible differences on my MA silver 500 7g speakers. Does this mean the DAC in my sr5011 is the bottleneck? I could also go for another dac but I like the convenience of my sr5011... I stream music via rpi3b (24bit flacs)
