Dayton MK402X Review (Bookshelf Speaker)
This is a review and detailed measurements of the ultra-budget Dayton MK402X bookshelf speaker. It was kindly sent to me by a member and costs US $70 a pair plus $8 shipping on Amazon. Note that this is the revised version of MK402 (hence the letter "X" after its model number).
From the front, MK402X looks to be a more expensive speaker than it is with chamfered edges and such:
The back gives out the budget look though:
Still, not too bad at all for what you are paying here.
I performed over 1000 measurement which resulted in error rate of around 1%.
Testing temperature was around 65 degrees F.
Reference axis for measurements was the center of the tweeter (by eye).
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Dayton MK402X Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Apparently the older version had a peaking tweeter and in this revision, it was brought down. That is a good thing given the broad dip proceeding it. This is not a bad response though. Beyond that dip we just have a resonance around 5 and 6 kHz. There is good bit of bass despite the little driver in there. Sensitivity is very low though as noted so you need good bit of amplification.
Good directivity results in similar early window and predicted in-room response:
Near-field driver measurements shows the reason behind the broad dip:
Seems like there is a slow roll off filter on the woofer, or a high order one on tweeter causing the two to not quite meet in the middle as far as level.
Port resonances are kept low which is nice.
I only dared to test the distortion at 86 dB SPL as it required ton of power to just to get to this level:
Horizontal Beamwidth is constant and broad for the most part which is good:
You have 10 to 20 degree leeway vertically as far as placement of the tweeter relative to your ears which is good:
Impedance drops to 4 ohm around 200 Hz:
Dayton MK402X Listening Tests
Other than needing a lot of power to get loud, out of box experience was fine. Really, it was fine which is not what one expects in this price range with so many compromises. I dialed in a broad EQ to fix the dip, pulled down the resonance between 5 and 6 kHz and the sound improved good bit to real hi-fi level:
There was enough bass to activate the one room mode in my room at 105 Hz to put in that filter. Half the time it was needed, half the time not. It reduced bass but also some high frequency harshness due to distortion harmonics. So you would want to play with that in your room.
The rear port makes noises that were audible around 2 feet and closer. So be careful in near-field listening. My tests were in far-field.
Conclusion
The expectation going into a review like this is that speaker is going to be junk unless proven otherwise. Well, it was proven otherwise! Somehow the designer managed to deal with the compromises just right to create a speaker that produces a very good experience with equalization. And not bad without.
Overall, I am going to recommend the Dayton MK402X. If you need a pair of speakers that can excite you with well recorded music most of the time and not cost more than a dinner, you have found it.
Any donations are much appreciated using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150
Looks like we have a $70 model to recommend, with $100 staying the Neumi that Erin reviewed (going off preference rating alone):
https://www.audiosciencereview.com/forum/index.php?threads/neumi-bs5-bookshelf-speaker-review.14404/
_________
Dayton also make a $105 powered version:
https://www.parts-express.com/Dayton-Audio-MK402BTX-Powered-Bluetooth-2-Way-Bookshelf-Speaker-Pair-with-3.5mm-Aux-In-300-467?
Sadly only analog or Bluetooth and no remote; would have been awesome to have optical and a remote, then it would be a good bedroom recommendation, as most televisions now have eliminated analog out.
Hopefully the response is the same, unlike the powered Neumi Erin recently reviewed.
Along with the Pioneer BS22 which routinely discounts to a similar price point.
Can't help wondering how much these cost to produce.
Well, if you wanted to build them yourself, drivers alone would set you back $50:
https://www.parts-express.com/Dayton-Audio-TD20F-4-3-4-Soft-Dome-Neodymium-Tweeter-4-Ohm-275-020
https://www.parts-express.com/Dayto...eated-Paper-Cone-Midbass-Woofer-4-Ohm-295-415
Their profit must be single digits.
_____
But it goes to show that good drivers can be had for real cheap, though they of course have limitations with distortion/sensitivity/SPL.
Like besides the BMR and the Peerless tweeter Dennis uses in his Pioneer mod, Peerless also makes this 3.5” woofer that is pretty good for $20/pair:
https://hificompass.com/en/speakers/measurements/peerless/peerless-tc9fd18-08
BMR still better in many areas, but this likely can be crossed lower.
_____
I'm sure they're not paying anywhere near retail prices for these drivers.
I think he means owners are paying people $70 to take the Pioneers away...
Well it’s got the same happy pink panther rating, so, if you think that is the right fate for ASR recommended products....
[sarcasm]They could have saved money if they didn’t chamfered the edges[/sarcasm]
I've had some custom speakers commissioned before and the builder confided that they were paying less than 60% of what the Madisound/Partsexpress prices were for off the shelf drivers direct from the manufacturer.
Much less if you buy in volume. In our case we placed a 1000+ piece order spread over a year — and, they were customised (magnets were shielded, phase plug was painted silver).
