Geert
- Joined
- Mar 20, 2020
- Messages
- 1,973
- Likes
- 3,639
Likely power supply.
From the images on Buckeye's website this seems to be a single OEM board implementation, there's no separate power supply board. It should be exactly the same board as in the Audiophonics-mpa-s250nc-amp-review which doesn't show the 20Hz linearity issue (although it also has reduced power at 20Hz). However, comparing the pictures there's one small difference I notice, the orientation of the coil next to the 2 large caps. Did Hypex make different versions of this board, one having worse performance?
