Sometimes I think that the best parameter to list them is their actual task: Gain and Power for a given voltage input.
Cause a lot of tricks can be played with them.
Oh, you can hear 1 GHz. Wow. Congrats!
No. See here. I just want to have fair information. That's all.He apparently wants arc welder performance for a low cost.
No. See this example. It's basically nearly empty.The class D amps as a class can do low frequency and low Z but the build needs to be much more heavy duty and have many more FETs.
Yes. You nailed it. You mentioned the GHz - not I.This is not constructive.
I don’t understand what you are here for. Are you asking for help understanding or are you here to teach us what’s up? Based on your comments and cheap shot for an obvious typo, I’m giving you a time out. Spend more time reading and learning and less time making comments that have no basis in fact.Yes. You nailed it. You mentioned the GHz - not I.
Your amplifier example is not representative of what I am stating. The example is still not a monster amp arc welder thingy. That requires more than your example. To have linearity both in frequency and power requires more than anything you have mentioned thus far. That and your example is a totally different build type.
I am not sure if it that was a typo actually. I think someone really tried to make a point of this amp having no power at 1GHz and he was responding to that.Based on your comments and cheap shot for an obvious typo
I think it has been explained many times, it is not 122W @20Hz so I presume you see that by now too. But, this amp has shortcomings at lower frequencues, and in my opinon all justifications to make it look like those shortcomings don't matter are, well, justifications only. This is not a great performing amp. Is it good for its price - I don't know, that is very subjective.The issue is, that you (correctly) say that the device provides 250 W @ 4 ohms @ 1 kHz but you didn't tell the customer, that the device only provides 122 W @ 20 Hz @ 4 ohms. I
The guy is complaining that the amp can not achieve its rated 250W at 20Hz if I understand him correctly. How is that "wanting an arc welder"?He apparently wants arc welder performance for a low cost.
For flat frequency response and linearity in power output more substance is required. I slang that and call it a arc welder amp. Usually costing several thousand+ or more. He expects too much for the expense of the class D amp.The guy is complaining that the amp can not achieve its rated 250W at 20Hz if I understand him correctly. How is that "wanting an arc welder"?
The 250w rating is at 1KHzThe guy is complaining that the amp can not achieve its rated 250W at 20Hz if I understand him correctly. How is that "wanting an arc welder"?
I disagree. You dont have to go too far or too expensive to find amps with better performance at lower frequencies. 6 channel Buckeye amp from 2020 that costs $1150 does much better for example.For flat frequency response and linearity in power output more substance is required. I slang that and call it a arc welder amp. Usually costing several thousand+ or more. He expects too much for the expense of the class D amp.
Yes, I understand. I am not saying there is anything wrong with the rating.The 250w rating is at 1KHz
Ohh, my apology. I re-read your post and see the syntax correctly now (I originally thought you implied the Hypex 250w rating was for 20Hz). My bad.Yes, I understand. I am not saying there is anything wrong with the rating.
That amp has poor power output linearity compared to a arc welder amp. The frequency linearity is not the best either. But we are commenting about an amp that costs very little for what it providesI disagree. You dont have to go too far or too expensive to find amps with better performance at lower frequencies. 6 channel Buckeye amp from 2020 that costs $1150 does much better for example.
Buckeye 6 Channel Amplifier Review
This is a review and detailed measurements of the Buckeye Hypex NC252MP based, 6-channel amplifier. It costs US $1149 as of this writing. The owner/builder is @Buckeye Amps on our forum. The looks are fine for a well-priced build: The unit is quite light courtesy of rather thin sheet...www.audiosciencereview.com
Same modules...as Amir pointed out even very subtle/miniscule things can change the resulting graph/rating between measurements (a loose test connection, etc).I disagree. You dont have to go too far or too expensive to find amps with better performance at lower frequencies. 6 channel Buckeye amp from 2020 that costs $1150 does much better for example.
You think that is what we see here; a measurement artefact caused by a minor mishap?Same modules...as Amir pointed out even very subtle/miniscule things can change the resulting graph/rating between measurements (a loose test connection, etc).
