Vini darko
Thanks for the laughs they totally do look aghast.I like how the power sockets look like a row of aghast faces.
You forgot to wear their Dragon Power Cable around your neck while conducting the test. Results are therefore invalid.
https://soundapproach.com/audioquest-dragon-high-current-power-cable-single.html
The 30 kHz and above don't make it past the power supply filter either.Well technically one can argue that the 30kHz noise can intermodulate and cause effects within the audible frequency range.
Deliberate typo?![]()
Hi Amir,
Any chance of getting the Emotiva CMX-2 common mode AC filter that also supposedly helps with DC offset on the powerline?
https://emotiva.com/collections/accessories/products/cmx-2
Thanks in advance if you can!
DC measurement is trivial using a multimeter so yes, I can do that.
I hope the receptacle recommendation is a troll. I can't tell any more these days.For this price you can get a Linear Power Supply off Ebay or a Synergistic Research receptacle to put in the wall. My two alternative choices instead of this.
