Requires java 8. Current java version is, iirc, 19. No thanks. Security nightmare.
Tried the REW installer a while ago, it fails under ChromeOS Linux (Debian), even as root. Looks like it will only work on AMD, not Intel.
Just tried again. Nope.
root@penguin:/mnt/chromeos/MyFiles/Downloads# ./REW_linux_AMD64_5_20_13.sh
Unpacking JRE ...
tar: lib/amd64/libfreetype.so: Cannot create symlink to ‘libfreetype.so.6’: Permission denied
tar: lib/amd64/server/libjsig.so: Cannot create symlink to ‘../libjsig.so’: Permission denied
tar: Exiting with failure status due to previous errors
Starting Installer ...
Invalid MIT-MAGIC-COOKIE-1 keyAn error occurred:
java.lang.NoClassDefFoundError: Could not initialize class sun.awt.X11GraphicsEnvironment
Error log: /tmp/install4jError544322289753602100.log
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at java.awt.GraphicsEnvironment.createGE(GraphicsEnvironment.java:103)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:82)
at sun.awt.X11.XToolkit.<clinit>(XToolkit.java:131)
at java.awt.Toolkit$2.run(Toolkit.java:860)
at java.awt.Toolkit$2.run(Toolkit.java:855)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:854)
at java.awt.Toolkit.getEventQueue(Toolkit.java:1736)
at java.awt.EventQueue.isDispatchThread(EventQueue.java:1071)
at com.install4j.runtime.installer.frontend.GUIHelper.invokeOnEDT(GUIHelper.java:436)
at com.install4j.runtime.installer.frontend.headless.AbstractHeadlessScreenExecutor.init(AbstractHeadlessScreenExecutor.java:83)
at com.install4j.runtime.installer.frontend.headless.ConsoleScreenExecutor.<init>(ConsoleScreenExecutor.java:25)
at com.install4j.runtime.installer.frontend.headless.InstallerConsoleScreenExecutor.<init>(InstallerConsoleScreenExecutor.java:6)
at com.install4j.runtime.installer.Installer.getScreenExecutor(Installer.java:84)
at com.install4j.runtime.installer.Installer.runInProcess(Installer.java:60)
at com.install4j.runtime.installer.Installer.main(Installer.java:46)
