Witterings
- Joined
- Feb 19, 2022
- Messages
- 356
- Likes
- 154
I ll ask here as its about the Wiim ..
Mine shipped today. I ll also get a pair of Wharfedale 11.1, have a Pair of Borea BR02 als alternative to test and even some other slightly smaller older speakers. But probably the Wharfedales will be used. It will be for music listening in the bedroom. Using Tidal mostly.
Any suggestions what to plug in between?
As is, as DAC/Amp connected to the Wiim Mini by Toslink?
For starters i can use my old Pioneer AVR but i d like something smaller. Not sure how much i want to spend. Probably not more than 200-300. If its less, thats welcome ;D
I have thought about a Loxije A30. That should be plenty powerful. Also the Headphone Out of that is a welcome addition. I have an older LG Quad Dac Phone that drives my Earphones without amp, but i guess something additional wont hurt.
Optimally it should have a remote, which the A30 has too.
Having read too much here i also eyed a Topping DX3pro+ & PA3s combo ... but i think thats already going overboard for that purpose ;D
Oh, and i might also use the Wiim for my x4700h in the living room to avoid Heos. Usually use a TabletPC or Heos App to stream there. But am not super fond of the latter. If it works well i might get a 2nd just for that.
I recently bought a new amp and looked at the Loxjie as well but 10% of Amazon reviews were 1 star which put me off which was a shame as it ticked all the other boxes.
I also considered the PA3s but in the end went with an SMSL AO200 as it's meant to be slightly more powerful and the "numbers" are marginally better.
The only thing is I already had an interface that takes Optical in and has line out, if I didn't have that I'd probably have bought a Topping E30 to go with it.
Your other alternative if you're buying speakers what about looking at some active ones with Optical in?
