Using the Optical In on a 2012 Mac Mini
boneman
Have a Mac mini outputting via M2tech USB dongle to spdif into my CD player's DAC. I recently read that you can plug an optical cable from the Tele into the toslink 'in' on the back the mini and then on the mini using a software app called 'Audo Hijack' redirect this input to the M2tech. I can choose the audio in and the M2tech as in/out but getting no sound. Anyone else have any experience with this? Would be great if I could get it to work.
Audio Hijack is great, but it needs to be recording for the audio routes to be active.
The publisher has a different app called Loopback that might be more what you're looking for.
cheers, I'll have a look!
If ever it can help, you can simply use AU Lab to create an Input/Output redirect .trak file or use the one I attached, which redirect digital input to output.
Inspect it, it's just a .trak file that will open with AU Lab, and that you can tweak to your taste afterward.
No need for "Audio Hijack". (this does not work on recent Mac/Os, but as you have a 2012... BTW I'm using this all the time on my Music MacMini 2012 server ;) )
More general information about how to use AU Lab here : https://developer.apple.com/library...mentals/AudioUnitDevelopmentFundamentals.html
