Many years ago I was into both car audio and home audio, so I learnt a bit about the differences between the two. The drivers are physically different because:
- they are mounted in a variety of orientations, e.g. facing up, diagonally, etc. Home audio drivers are almost always mounted vertically. In cars, the drivers also have to tolerate bumps and shocks as the car is moving. This means the suspension has to be more robust, which decreases efficiency.
- related to above, the gap between magnet and VC has to be larger, which decreases BL, which again decreases efficiency. The magnet and voice coil assembly has to be larger and more robust to compensate, which increases cost.
- they have to tolerate a wider variety of environmental conditions
- they have to be made physically smaller, which means less bass extension. So large cone excursion designs are more common.
- speaker enclosures in cars have to be smaller, so the Vas is smaller. Smaller Vas = higher Q and lower efficiency.
Also, car batteries supply 12V so drivers have to be low voltage high current designs, meaning that impedance is usually lower (about 4 Ohms). Home audio drivers are the opposite, they are high voltage low current designs. This means car audio amps have to deliver a lot of current to drive inefficient speakers, and be built into smaller enclosures. Back in the day, we only had Class A/B amps - some of the high current designs then ran into problems with heat dissipation and there were only so many places in the car you could mount them and still dissipate heat efficiently.
In addition to the above, DSP was mandatory if you wanted any hope of success. I had no way of measuring time of flight so I had to measure the distance and calculate time alignment from that. The DSP in my car was rudimentary compared to what I am using now at home, which added to the challenge. DSP's had to be built into the head unit which increased their cost.
