JP
Next question, which adapter did you install, what's your experience with it? A few brands on the market. Many thanks in advance.
PS: we have something in common, I do brake maintenance and more at my care as well.
I'm using the ISUDAR unit. Biggest complaint is I've had a few lock-ups when navigation using Waze was active and I did a quick stop turning off the car while the phone never left the range of the car, like fueling. I think it'll reset itself after several minutes, but I end up power cycling using the PCM fuse.
Annoyances are that all the volume levels (nav, Siri, etc.) are relative to the main volume control, which can be quite jarring if you have the music loud or had the music loud but forget to turn the main volume down. Also the audio from the board is analog and there is a fair bit of noise, but not a real issue in that car as it's not a quiet cabin, and we mainly drive it with the top down.
Had I to do again I'd probably look at the Mr12Volt unit as it integrates with digital audio. If you want to use the factor mic you need to hack their harness a bit, and you do need to find a place to put the external box. Not sure how they handle the volume controls though.
