No conclusions/comparisons can be drawn on power output. An 8 channel amplifier should be tested to clipping with all 8 channels driven, even if you only monitor 2 of the 8.
Please enlighten me on scenes in movies where 8 properly hi-passed speaker channels are fully loaded to the point they are all simultaneously drawing >311wpc.
I understand your point, on a technical critique sense, but it’s irrelevant/unfair for real world applications. Unless the owner likes listening to 30hz full scale sine waves on 8ch you’ll never come close to PSU saturation.
So only the lower noise is better (SINAD 8m 106 x 98 Buckeye) for the 4.3x price difference (8m 9500 x 2200 Buckeye).
But if we consider 4 x Buckeye stereo NCx500 at around 4400 usd one would have better power (
around 640W for a single SMPS1200) and
similar SINAD 106 still for half the price.
Yeah this is the point I made earlier. This doesn’t make sense unless you have “fuck-you money” and want everything to be in the trinnov ecosystem.
I think there’s merits to their approach of optimized gain staging from processor to amp over the DB25 but without comparative data in front of me, I’d wager the performance advantages of <1/4 as costly solutions far out-weigh a few DB of noise (in the -100db range) in terms of audibility/subjective quality for a buyer.
I’d much rather grab the buckeye 502 amp, and spend the $7300 saved on more pertinent things like nicer LCR, room treatment, subwoofers, which would undoubtedly be more beneficial for the final result than buying this amp.
The laws of physics don't allow a 15 amp, 120 volt supply in US to do that. That would amount to more than 4KW. I don't even know if you can do it in your neck of the woods. No amplifier meant for home theater application requires all channels driven to max.
Exactly. It’s even more prevalent in my line of work (live sound).
See this.
Amplifiers capable of 8200wpc (x4) can perform at the limit off of a 264v@32A leg of 3 phase (usually at 220v@32A, one leg of 440v3P) totally fine under real world music conditions.
