I'll puzzle you a little more by pointing out that if the SINAD is your aim the numbers you read are usually for the full output of the DACs and for a specific frequency (that's for all).I’ve been reading a lot (focused mostly on trying to figure out Sinad/distortion/etc.) and feel like I’ve gotten nowhere… so, I’m just going to accept I need to ask and see if someone here can explain.
I’m strongly considering the wiim ultra (over 120 sinad per company specs) paired with the Fosi monoblocks (over 100 sinad with xlr but mid 90s with rca).
1. If RCA is used (wiim doesn’t have xlr), SINAD is such that the amp is no longer in the excellent category, right?
2. In general, what is the point of having a DAC with 120+ SINAD score if amps reviewed here aren’t getting that high? Seems like you’ll always be at the mercy of the amp sinad?
3. If I use the wiim ultra, am I losing that sought after SINAD score as soon as it hits the Fosi monoblocks via rca?
I realize after reading that sinad is more complicated than just a number and actually takes into account a couple of things. That being said, I was really excited for the above pairing until I realized how far different the SINAD scores were. Seems like I should just wait for the wiim amp pro to come out (claiming 120 SINAD).
Also, sorry for the novice questions. I’ve been trying to do my due diligence, but am not getting good answers. Thanks!
Haha thanks. I watched Amir’s videos yesterday on the subjects and have been doing some reading. There’s probably a reason I didn’t become an engineerI'll puzzle you a little more by pointing out that if the SINAD is your aim the numbers you read are usually for the full output of the DACs and for a specific frequency (that's for all).
I would urge you to study the Power vs Distortion charts (all of them,for amps) and the IMD vs level and THD+N Ratio vs Frequency for DACs,for starters.
According to Fosi: The following possible advantages (see first FAQ entry):What would be the benefit of two 48v 10a over two 48v 5a power supplies?
Most important to me: will it be completely out of the audible range whether or not I use rca or xlr with the Fosi? In that case, I don’t care and will go for that setup as it is easy/cheaper than other options I’m considering…
They have 24 months warranty, so the longevity can be at least 24 months.Any idea what the longevity of the Fosi Audio V3 Mono amp should be compared to Hypex or Purifi amps? I have always stayed away from external power supplies in the past as they typically have been the weakest link in my experience.
Wondering how the warranty term works - sending unit back to where?They have 24 months warranty, so the longevity can be at least 24 months.
Guys, this is throw away stuff. I know that irritates many people. I've been apart of the PA5 debacle with 3 units and Topping didn't miss a beat. Keep on producing and minimize the problems. These companies seem to have found the market is resilient to possible reliability problems as long as top performance, cheap gear gets released quickly. I'm ok with it. I was really upset when I had $2500 worth of broken NAD gear. I was only annoyed with a $350 Topping amp. I won't blink an eye is a Fosi V3 mono takes a dump and I'll buy the next equivalent thing.
Depends where you bought it. If you buy from Audiophonics you send it to France.Wondering how the warranty term works - sending unit back to where?
China?
So you assume it would be an audible difference? For the price of the Purif you could by 10+ FosisThat would be a trade from quality to trash. Downgrade in performance and longevity not to mention the Purifi runs much cooler.
The difference in noise and output power may be audible, depending on your speakers' efficiency and listening distance.So you assume it would be an audible difference? For the price of the Purif you could by 10+ Fosis
The purifi is a state of the art amplifier, with excellent performance in every area, however I doubt you will hear any difference other than power. The noise levels are also low enough to avoid problems even with high efficiency speakers in my opinion.So you assume it would be an audible difference? For the price of the Purif you could by 10+ Fosis
You might hear a tiny difference but it in reality it is unlikely. Your Onkyo outputs a decent amount of power but it is not as 2 Ohm stable as the Fosi so you might hear something there but the differences might exceed your ears sensitivity.Based on the parameters and amirm measurements, it should be a significant improvement for me. Unfortunately, I don't have personal experience with any D-Class amplifier yet. Is there a chance that even with these "cheap" boxes I will really move up in sound quality?
Unless you have an actual issue with your current Amp, like strong hissing noise, obvious clipping at higher volumes, or an audibly skewed response, no new Amp is likely to move you up in sound quality.Is there a chance that even with these "cheap" boxes I will really move up in sound quality?
I think so! I am currently using a $200 SMSL AO200 for my 2 channel setup. If I remember correctly it rated at an honest 7owpc into 8 ohms. It sounds significantly better than my $1200 Dennon avr 3400x with a fluffed 100wpc channel rating. That being said, the fosi measures much better, with much more power.Hello everyone,
I plan to purchase these monoblocks as a replacement for my oldschool AV-Receiver onkyo TX-SR700 (from 2002 at original price around 800$). I'm currently running it (in stereo mode) as a temporary replacement for my original power amp (same price range and even slightly older than the onkyo), which has definitely gone to silicon heaven.
I would care more about the protections involved than anything else.Hello everyone,
